Question about Lexmark X5470 All-In-One InkJet Printer
Error printer is saying error #1203,cannot use it
    Problem Solver:
  • 14 Answers
There is a problem with one of the cartridges.
What you nee to do is first remove the cartridges and close the carrier lids. Unplug the printer from the electrical outlet, wait a few seconds, then plug it in again. If the power button isn't lit, turn on the power. Reinsert the printer cartridges, and you should be good to go.
If you see the error again, then repeat the above procedure and only put in the black cartridge instead of both. If you don't get the error, then try putting in the photo cartridge. This will let you know which cartridge has the problem. If the black alone causes the error, the black one is the problem. If you see the error when you insert both, but not with the black, then the photo cartridge is the bad one. Get a new cartridge (either black or photo) and that should take care of the issue.
Posted on Jan 21, 2009
Printer says error #1203 what do I do
Problem Error 1203 ; 1203 error message; 1203 cartridge error; Cartridge short error Solution Overview
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In-One (AIO), or by a short in one of the printheads.
Resolution
  • If the problem occurred immediately after the printer was purchased and unpacked from the box, please contact Lexmark Technical Support for assistance.
  • If the problem is occurring during the normal printer lifetime, the procedures below will help you to resolve it.
Troubleshooting a Communication Error between the Cartridge and the Printer click on this link and follow the steps listed, hope this helps! http://support.lexmark.com/index?page=content&id=SO3683&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=LEXMARK_X5495&searchid=1286737658844 Please leave rating ;) thanks
Oct 10, 2010 | Lexmark X5495 All-in-One &USB...
Printer says cartridge error: error 1203
Remove both ink cartridges and check the bottoms to be sure all of the tap is removed. Small pieces of tape frequently are stuck to the cartridge bottom causing errors. Confirm you have the correct cartridges (# 34 for Black(HIGHYIELD) and #33 for color). Reseat the cartridges and try again.
Sep 06, 2010 | Lexmark X7170 All-In-One InkJet Printer
I put a cheaper replacement cartridge in for the printer and it says on the printer Error#1203. It also says cartridge error
Cartridge Error: 1203 Your print cartridge has a short.
  1. Press Power to turn your All-In-One off.
  2. Unplug your All-In-One from the wall outlet.
  3. Plug in your All-In-One.
  4. Reinstall the cartridges.
Hope this helps
Mar 23, 2010 | Lexmark All-in-One Printer with PictBridge
Lexmark 7170 error 1203 when it turns on
1203 Printhead
short-circuit in
printhead.
Replace print
cartridge(s).
Dec 08, 2008 | Lexmark X7170 All-In-One InkJet Printer
Error 1203
Try this may do the trick
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Aug 15, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Error Message 1203??
These steps are for a Lexmark 4200, but I suspect they will work for your printer as well:
If this does not resolve the problem, see More troubleshooting options, or replace your cartridges.
Source: http://www.lexmark.com/publications/pdfs/4200/eng/trouble.html
Aug 04, 2008 | Lexmark P4350 All-In-One InkJet Printer
I am getting a message error 1203
Try this first see if it will help.
or
Aug 02, 2008 | Dell 924 All-in-One InkJet Printer
Error 1203 and carrier jam error
Error 1203 on a Lexmark is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
May 24, 2008 | Lexmark P915 InkJet Photo Printer
Lexmark X5470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
