Question about Mag Innovision lt456s 14" Flat Panel LCD Monitor
Monitor Display I've had my mag monitor for probably 2 years now at the most. I've never had any problems with it. I always leave my computer on, and now for some reason the screen goes completely to white when I turn it on. I turn it on and off a few times, sometime the image shows up very faded and blotchy. I mess with some cords and things, turn it off and on a few times and eventually the screen shows up perfectly again. It's very upsetting; I spent alot of money on this and it shouldn't be screwing up so soon. No one thing seems to make it work again every time. I've restarted the computer and it seemed to work, but the next time I tried it, it didn't work. Messing with the connection to the compuiter (jiggling it, disconnecting it and reconnecting it) has worked, but not this time. Turning the monitor off and then on has worked, but not always. And it doesn't help that I leave the monitor off with the computer on, or even when I turn them both off.
  • mystic8612 Jan 07, 2009
    It's an LT716s
  • 102 Answers
See ur moniter is nearly dead...
dont try to on?off it again and again
take it to service center
it happened to me too
its nothing just a small thing which they will change it.
its a bit costy but not more then ur moniter
Posted on May 17, 2009
Slightly Blurred images on monitor
If it is a CRT monitor then the tube may be going out. A new monitor is about $129 for many of the cheap monitors I suggest you swap it for a newer flat screen.
Dave
Jul 04, 2017 | Mag Innovision InnoVision 786 PF 17" CRT...
MAG LT1919W Wide screen flat panel monitor
check for a different cable problem sir
if no the leave the monitor plugged off from wall power for one night and check if it works
Aug 03, 2008 | Mag Innovision Computers & Internet
I have a MAG INNOVISION LT765s LCD monitor. When the computer boots up, the power button on the monitor won't stay on so the display won't come on. It sometimes takes an hour of fooling around with the...
I have had similar problems with my Mag LCD monitor. I recently dicovered that the problem was with the adapter and not the monitor. Try replacing the power adapter.
Sep 21, 2009 | Mag Innovision InnoVision LT765 17" Flat...
MAG 700P monitor display goes black after 60 seconds
Can you send pictures of the power board to me at tech@ccl-la.com I will check our service manuals for the model and get back with you about a solution.
Buddy
Corporate Computer
Jun 29, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Mag Innovision LT917s 19 inch monitor- On and Off !!
Replace it.  It would probably cost more to get it repaired.
May 28, 2009 | Mag Innovision LT917S 19 inch Monitor
MAG Innovision LT2219WDB monitor will turn on -picture up clear as ever and 2 seconds screen goes black, turn it on and off screen comes up clear as always and 2 seconds goes black. will not keep the...
I have the same problem with a customer's monitor (LT716S); it turned out to be damaged power supply board. As I understand it, MAG has a 3 year warranty on parts, will probably charge you a flat labor fee plus shipping. If you do not have your purchase documentation for warranty, dump it and replace. If you can, then you may wish to have it repaired.
My customer replaced theirs; I am trying to purchase replacement parts to repair...good luck.
Feb 24, 2009 | Computers & Internet
Mag monitor doesn't display bios post
I have no experience with the DVI links because such technology is still unavailable here in Argentina. We have DVI video cards but finding a suitable DVI monitor is another (long) story.
I think that your card (that has 2 DVI ports) is initializing one port first (the primary one) and then, when windows starts, it initializes the other and outputs video from both ports.
Try connecting the monitor in the other DVI port.
If your card has a VGA output, the VGA gets initialized first.
May 06, 2008 | Computers & Internet
Mag lcd monitor
probably capacytor problem in the mainboard, take it to the lab it will be cheaper then buying new one
May 06, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Mag Innovision 765S Screen Flashes on and off.
It sounds like it is trying to re-synchronize it self and not going back the the default setting. Compare the resolution of the game to your monitor capabilities.
Jerome
Dec 29, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
Power light flashes with no display
That usually means that the connection between the PC and the monitor has been interupted- check that the cable (probably has blue ends) between the two is firmly connected, and power it back up. If that doesn't work, you have one of three problems; a broken VGA cable, a broken monitor, or a broken video card. Finding out which- you'll actually need someone tech-savvy there to help you figure that out. Try plugging the monitor into a different computer. If that fails, use a different VGA cable (cables are pretty cheap at monoprice.com), and if that fails, it's your video card.
May 23, 2007 | Mag Innovision InnoVision 786 PF 17" CRT...
Mag Innovision lt456s 14" Flat Panel LCD Monitor Logo
174 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
