Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Can't program remote
We just recently moved and had to buy another remote for our Craftman Opener...# is 319.1870
we got some instructions but it did not work...the light is not on on the pad on the wall( it is on on the other door)...also it has opened by itself a number of times...can you hlep...or can you give me a manual for the opener
    Champion:
  • 244 Answers
Buy manual from sears. if light on control panel is off, does unit have power. check outlet. might be a bad circuit board, PS-when you first plug unit in, light bulb on motor should light.
Posted on Jan 15, 2009
Craftman 139.53753 remote how to program
Push the learn button on the opener
an then hold the remote under the opener an hold the button on the remote till the lights flash on the opener you have about 10 sec. to do this
Jun 25, 2014 | Sears Craftsman LiftMaster Chamberlain...
My craftman 139.52606 opener does not have a learn button to set pin on keypad. I had keypad working at one time but since I changed the battery I can't rember how to reset the keypad.I also changed...
If the keypad is hardwired, do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
HI seems like motor works but chain does not move .Model is craftman
Remove the cover and check the drive gear. It will be stripped. The part number is 41A2817 and is available at any good door opener service company. It comes with instructions.
Jan 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftman Garage Door Opener is approx. 7 yrs old. Remotes work fine. Keypad acknowledges receiving code, but then will not open door. Installed new bsttery.
If your keypad is the same age as your door and worked before it has probably just quit. If it is new and you have programmed it and it still doesn't work it may be the wrong one for your model opener.
Oct 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
13953992D need a replacement manual for that model #. craftsman garage door opener. moved in to house, former tenant took remote, do not want to buy a new one. do i have to just buy the remote? or can I...
A replacement remote for your unit runs around $40.00 and the manual is $5.00. The remote is part number 53753 and the manual is 114A3129. FYI the manual will not have instructions for programming your car. The cars owners manual should have those instructions. The frequency of your opener is 315mhz and if your car is older than 2005 it most likely will not work at all.
Aug 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Professional and Clicker Programming Problems
The Security+ system is a rolling code system and is digital, so it will work with the Homelink in vehicles and with the remote control units that come with the opener. Also with new remotes that are purchased specifically for that opener. Your "clickers" require specific instructions and you need to use the Smart Learn function in order to use them with this opener. In addition, check the Brand Switch settings to be sure they apply to your opener, and the correct Smart Button color on the opener. Read carefully to determine whether you need to set ANY dip switches at all or can you just set them all to off depending on your opener? Check the instructions carefully. Here's a link to the page where you can download a copy of the Clicker instructions if you don't already have it:
. Clicker Model CLT1D Remote Control Owner Manual
May 14, 2009 | liftmaster Chamberlain Garage Door Opener...
I CAN NOT PROGRAM MY BUILT IN CAR REMOTE ON MY NEW 139.53985DM
didnt try everything cause if you did, it would work! Get two people and garage door opener. One read manual from car under Garage door" or Homelink while other pushes button. When manual says if this did not work or if you have security plus or rolling code, continue with other instructions. You will need a working remote and will need to pushh learn button on motor logic board.
Dec 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftman garge door opener changing code on key pad
having all the remotes you want programed with you, find learn button on back of opener. hold button until little light goes out- no remote will work now, with each remote Press learn button once,Press big button on remote-light bulb on opener will blink on/off if bulb is working-do this each hand held-keyless is same way, put you 4 #'s in HOLD enter button-light bulb blinks on/off you have 15 sec. for each time you hit the learn button. also best to start off with new 9 volt battery before you start programing
Aug 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
57 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
