Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Electrical I'm trying to get 12 volts of power from under the hood to hook up my heated visor for my helmet. The only power source I found had over 110 volts. When trying to check the volts from the same power source as the headlight I couldn;t get a reading. Is there some place to find an electrical schematic on-line? The sled was bought used and had no owner's manual with it. Please advise if anyone has a solution or a tip. Thanks
  • case_069 Jan 07, 2009
    Sorry forgot to mention the sled is a 2002 polaris 550 fan cooled.
    Problem Solver:
  • 5 Answers
If its a polaris look for the yellow wire to the hand/thumb warmers the other side goes to ground.
Posted on Feb 03, 2009
How do I hook up a heated visor helmet to my 95 vmax 600
Find a wire that has 12 volts or more on it when the engine is running. Wire in you plug in connector to that, I would put an inline fuse in it also.
Dec 27, 2016 | Winter Sports
I have a 14 volt source but when I try the winch in either forward or reverse the voltage drops to 4 volts. The drum is not seized because you can pull the cable out easily by hand.
Not only do you need a 12 volt supply (13.8V) to operate this winch, but you also need a.) wire large enough to carry the electrical load, and b.) a power source that has the necessary current (amps) to turn the motor.
If you have wires that are too small, they will heat up and not be able to deliver the current (amps) required by the motor. If your power source is to small - it can not supply the current required. The result of either conditions is "voltage drop". This can be explained the same way your car needs a 12 volt car battery to start. If that car battery was dead, you couldn't connect eight "D" cell batteries (8 x 1.5volts = 12 volts) together and attach to the car's battery cables and expect it to start. This is because the amount of current available in the car battery is hundreds of time greater than eight "D" cell batteries - even though when the D cells are connected in series - both systems deliver 12 volts.
If neither of the above conditions is present, then there could be an electrical problem with the drive motor itself. This could be a shorted / melted winding or other electrical connection that is not right, even if the drum spins freely.
Apr 04, 2011 | Electric Superwinch LP8500 Series Utility...
It runs the battery down
Does your frig have 110, Gas and 12 volt setting? ... or is it auto select?
This is the way they should work ... if there is 110 Volts, it should run on 110 volts. The device is still controlled by 12 volts but the heat source is electric. If there is no 110 volts, it should switch to gas as a heat source. Same deal with the control, runs on 12 volts. If there is no electric and no gas, it should select 12 volts for a heat source ... same deal with the control. Problem with 12 volt source for heat is it GOBBLES up the power in your battery.
How is your battery? Do a volt test on the battery and the charger. Charger should run about 14 volts. Battery should provide at least 11 volts. If it is such that you can measure the acid, a good reading is 1200. Your charger can provide only about 15 amps charging power. Your battery should be able to provide up to 110 amp/hours.
If you do have electric and gas, it may not be your frig that is killing the battery ...
Thanks for your quesiton @ FixYa.com
Mar 21, 2011 | Dometic RM2852 Refrigerator
What do i need to stop my vehicles power source overpowering my head unit
Your vehicle's power source, (battery/Alternator), cannot "overpower" your head unit. A car's internal electrical system runs at 12 volts. Period. Your head unit requires 12 volts to operate.
The head unit will still work at 13-14 volts. If your cars electrical system was supplying more than 14 volts all your internal electrical devices would begin to fail.
You have some other problem.
Dec 22, 2010 | Car Audio & Video
I have a 1994 silverado, The Heat/ac controls do not work (don't even light up) I have found no blown fuses but have no Idea what else to look for.
computer does not have anything to do with your heater controls. With a working control box everything should work, if not them you'll have to deal with the electric actuator motors. microprocessor is in the control panel.chevrolet-silverado-2500-evaporator-heater-parts-diagram_thumb.png1) Evaporator core2) Evaporator core Seal3) Evaporator case Upper4) Evaporator case Lower5) Heat shield6) Seal kit7) Heater core8) Heater case9) Blower motor10) Fan11) Resistor12) Blower case
13) Blower case Seal14) Valve Air inlet15) Valve Mode16) Temperature Temperature Right17) Temperature Temperature Left18) Valve Defroster19) Actuator Air inlet20) Actuator Mode21) Actuator Temperature22) Lever Mode23) Harness
Dec 13, 2010 | 1994 Chevrolet Silverado 2500
I know this is a vague question. (trying to help out hubby) I am currently at work, however, our norcold elect/gas fridge/freezer in our mallard camper stopped working properly. the lp gas light is lit,...
Don't be despirate.
You need a little more knowledge ... I'm here to give it.
Your RV refrigerator requires 12 volts to operate; on gas or on electric ... it needs 12 volts - period.
Now then, your frig will get 12 volts from your 'power converter' AND/OR your battery. You do have a battery in your unit, correct? If not - why not? Get one. (Your power converter cannot provide all the 12 volts you potentially require in all circumstances. It is there to charge the battery, which CAN supply all the 12 volts you require. The converter can probably put out 15 amps - your battery can put out 100 amps or more (@ 12 volts DC). Relying only on the converter for your 12 volts will cause over heating and will eventually destroy the converter. Batteries are about $100.00 - converters are about $300.00.
As you know, your frig will run on gas if you are plugged in or on generator ... that allows your frig to get the 12 volts required to run the controls.
What about electric operation? If you are plugged in or on generator, you can run on electric because your Norcold has 12 volts from the converter and/or battery.
Whats going on? Your absorbtion type refrigerator requires a heat source to boil the ammonia mixture to create "heat removing" (you can't really cool anything ... only remove the heat from it!) You can heat the ammonia with a flame or with a electric CALROD. However, the control panel that drives the whole operation runs of 12 volts.
You have a battery and generator and are plugged in and it still doesn't work? You will find a fuse on the control panel in the compartment accessible from the outside of your unit. Check/replace the faulty fuse and you will be back in business.
I hope this helps you and hubby with your Norcold Frig. Thanks for your interest in FixYa.com. If you found this solution to be helpful, please vote. Thanks
Aug 02, 2010 | Refrigerators
No power to the unit. I have checked the power source at the back of the unit and I have power there. I replaced the circuit bourd on the back of the unit and still don't have power to the unit inside the...
if this rv frige is 12 volt check the voltage inverter under the bottom of the frige if it is gas check the electrical heating element at the gas flue befind the frige.
Jul 16, 2010 | Dometic Refrigerators
I want to re wire an electric motor for low volt
Look on the name plate. If it says under 'volts' 120/240 that means it's dual voltage and you can use either voltage to run.
Sep 25, 2009 | Electric 1hp 1800RPM 56C Frame 12 Volts Dc...
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
258 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
