Question about Dryers
I have a kenmore 80 series dryer that won't come on
It is getting power. I pulled the top off and checked the voltage. The belt is okay. The light comes on inside the dryer. What should I look at next?
  • 198 Answers
Replace thermal fuse. Part number 3392519
Posted on Jan 07, 2009
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
My series 80 Kenmore dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 30, 2011 | Kenmore 800 6983 Electric Dryer
How do I take the top off of a Kenmore 80 Series?
You remove the back panel that is how your get to everything. once the back panel is removed you will be able to put the belt and the idler pulley on. Please rate
May 24, 2010 | Kenmore 64852 Electric Dryer
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
I have a Kenmore Series 70 dryer wont start, just hums
Check for correct voltage at the terminal block on the back of the dryer, where the power cord attaches to the dryer.You should be getting 220/240 volts, check by way of a voltage tester.
If the voltage is correct, then could be the motor capacitor or the motor itself, or start button?
Good Luck !
Feb 07, 2010 | Kenmore 63942 Dryer
Trying to find the belt
if it has the lint filter on the top pull it out take the two screws out pop the lid up and you should be able to see the belt
Apr 24, 2009 | Dryers
The drum of my Kenmore 80 series electric dryer is not turning
sounds like you need a new drum belt. start by taking the top off then the front panel will have screws inside for removing the front. then once the front is off you will see the motor and where the belt should be. if the belt is broken, replace it, if not just put it back on the motor and idler pulley.
Dec 28, 2008 | Kenmore 659 Electric Dryer
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
150 people viewed this question
Top Dryers Experts
