Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp AR-150N error code E7
The paper, on a single page or multiple page job, will Intermittently stop in the paper exit area with apx. 4" sticking out of the machine. It seems to stop at the same location each time. Remove the paper and power cycle the machine quickly and flashing "E" then "7" will display. I believ the "2" will sometimes follow as well. Wait longer to power cycle and it will go back to normal. Is this the LSU? If so, should I bother to clean it if the print looks ok or just replace it?
Thanks.
  • brian975 Jan 15, 2009
    I found that the Xerox XD100 series scanner will work as well and a lot cheaper to purchase. I did not get a chance to switch them out yet but believe that it will do the trick.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
The E7-02 is a laser unit problem. I do not know the part number for the laser sync motor but you and just replace that instead of the whole laser unit ( alot cheaper). If I can find that part number I will get it to you. Remember , if you do replace the motor, replace in as clean and still air area as possible. If something gets into the area of the laser/motor, it could scratch one of the lens on the laser head and it would be trashed.
Posted on Jan 07, 2009
How to resolve the code error for Sharp AR C262M
I found this for a different model in the same family. Sharp AR-BC320 it may be the same as your problem.
On page 2 it says E7-21 is:
LED controller initial trouble (Cyan)
On page 4 it gives a couple of things to try to fix the problem.
http://olsonbros.com/sharp/support/pdf_trbl/trbl-arbc320.pdf
Sep 21, 2016 | Sharp Office Equipment & Supplies
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
Sep 25, 2015 | Sharp Office Equipment & Supplies
My sharp al2021 showing f5-02 and e7-11 what can do to work
The service manual was not available for the AL-2021 but the error codes are the same for the AR-5316
F5-02 error cause and remedy
Sharp AR 5316 Service Manual Page 27
E7-11 error cause and remedy
Sharp AR 5316 Service Manual Page 26
Jan 07, 2015 | Office Equipment & Supplies
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-m205 showing e7 error code
Duplex model memory error/ Image data error
Detail 1. The memory capacity for the duplex model
machine is wrong. Insufficient memory
capacity.
2. Duplex setting is set for a single surface
model.
Apr 08, 2011 | Sharp AR-M205 Copier
Sharp AR-150N displaying F2 Error code.
Hello sir; I can't find this error code in my manu please check your code again.
Aug 12, 2009 | Sharp Office Equipment & Supplies
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
E7 problem
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
600 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
