Question about HP Compaq Presario SR2150NX PC Desktop
I have a compaq presario SR2150NX and i need to replace the CD drive. What should i buy
    New Friend:
  • 26 Answers
The solution is that do not replace the cd drive !!
You could buy a new DVD writer drive which can be very useful.
You can use both "cd drive" and the new "dvd drive" at a time.
New DVD drive comes only for rs.1200/- to 1500/- .(LG,Samsumg or moserbaer).
Yes ! you can operate them normally as usual.
Only call your computer engg. to make connections or the shopman to fit the dvd and cd drive.
Posted on Jan 07, 2009
Adapter for cd/dvd power cable inside
Being that you didn't give detail about the pin configuration on the drive vs the cable (ATA to SATA, SCSI), You could return to the place you purchased from and have them correct the cable issue. 2. You could visit Radio Shack, Best Buy, etc to get an adaptor that will connect the two together.
Good Luck
C2S
Dec 22, 2011 | HP Compaq Presario SR2150NX PC Desktop
Are memory sticks from a compaq pressario 7922 compatiable with my compaq preasrio sr2150nx ?
Compaq Presario 7922 Computer takes the PC100 SDRAM DIMMs RAM Type and the SR2150nx has the PC2-4200 DDR2 SDRAM memory, SORRY- it will not be compatible
May 06, 2010 | HP Compaq Presario SR2150NX PC Desktop
Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Apr 14, 2010 | HP Compaq Presario SR2150NX PC Desktop
My dvd drive doesnt open on my Compaq Presario SR2150NX, i finally got it open with the manual open, but im trying to install windows 7 on it, but when i try it says theres something wrong with something...
Check to see if the DVD drive is connected to the power supply and the IDE connectors.
Can your dvd drive be displayed in "My Computer"
If yes, then it is connected, so, you will have to reinstall the drivers. They could be corrupted?
Thank you for using Fixya,
Kenneth
Jan 17, 2010 | HP Compaq Presario SR2150NX PC Desktop
I have a Compaq Presario, model #: SR2150NX W/120GB HD
You should be able to add a SATA drive to that machine (IDE should also be available to you). The spec drive in your machine is a 120GB, you may get a decent increase in speed if you use a newer SATA hard drive with a fresh install of Windows on it and simply put the existing drive as the slave or drive 2.
Mar 24, 2009 | HP Compaq Presario SR2150NX PC Desktop
Cant get compaq Presario SR2150NX to start
get in the bios settings and make sure to have the hard drive in the boot line, try different settings like SATA/IDE compatible mode if the drive is not seen by the motherboard, try different plugs.
if the bios settings don't stay , check the position of the clear cmos jumper and change the backup battery of the motherboard.
Try to boot from cd. maybe a virus took off the boot flag from the hdd.
Feb 13, 2009 | Compaq Computers & Internet
Drivers for PBSD drive in SR2150NX Presario PC
Yes, you should be able to. Here are the links for the 32-bit and 64-bit versions of Windows Vista.
32-Bit
64-Bit
May 28, 2008 | HP Compaq Presario SR2150NX PC Desktop
How to upgrade a new compaq presario SR2150NX?
Add more RAM, 512MB ram will slow your computer down because when you run out of ram the computer uses the hard drive as vitrual ram. I have 4GB in my Vista machine and it is faster than XP.
Another suggestion is to turn off the hard drives indexing. Right click on your "C" drive and unhook the "index this drive for faster searching" box.
Jan 05, 2008 | HP Compaq Presario SR2150NX PC Desktop
HP Compaq Presario SR2150NX PC Desktop Logo
121 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
