Back to:
Tags:
GE JKP30WMWW 27
Ge wall oven display says F7 (by 2 users)
posted by Waterhead on May 29, 2007
Display says F7 and alarm sounds
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jan 13, 2008
I reset the circuit breaker ans slid the slice of paper between as directed.
F7 still occurs.
Please help. An I doing somethin wrong?
Best Solution
posted on May 30, 2007
FixYa! (100)
Powerman
Rank:Guru Guru
Rating: 92%, 216 votes
Your problem is most likely caused by a short between sections of the ribbon cable between the touchpanel and the electronic control. The solution is to insert a slip of paper between the sections where it exits the touch panel. See the attached photo. If you have a metal touchpanel, insert slips of paper on either side of the ribbon cable as well. CAUTION: Be certain to turn off the power to the oven before you poke your fingers in and around the touchpanel. My solution has worked for hundreds of folks. Don't worry about the paper burning. If you have questions, contact me at hutchipop@yahoo.com.
Comment by Powerman, posted on May 30, 2007
Here is the photo showing my solution. I have now shared this solution with over 800 individuals. Most report success. This problem is caused by a design defect in all GE and Kenmore ovens.
The technical name for the problem is called Dendrite growth. Many electronic devices have failed because of this well known problem. GE could have prevented this problem for only a few pennies. Do a search on GE oven F7 to learn more about this wide spread problem.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Ge wall oven display says F7:
I don't want to Accept this solution
Solution #2
posted on Feb 29, 2008
Not Rated (0)
pjdm
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Looking for two year for this solution. Piece of card behind the ribbon and I cleaned the contacts just to be sure. After years of random F7 in the middle of the night, it all works perfectly again. Thanks so much. Saved key panels and electronics replacements.
Thank You!
Can you Help with these Ovens problems?
GE JKP30WMWW 27" Built-in Single Electric...
I have just had installed a Built-in Oven - BF641...
frigidaire FEF74ASE takes too long to preheat 10-15 min....
The problem occurs when the oven is set to come on at a...
elctric walloven willnot heat
We turn off the circuit breaker and if we turn it on and...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
