Question about Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill
MAKITACHARGER 220v to 110v problem after using of right converter
Hi ! recently I bought an DC18RA μakita charger 110v to use it in my country
at Europe and bought also a converter from 220v to 110v-1600watt 50-60Hz.
When I put the converter in 220v and after the charger on converter I heard
a sound like bzbzbz and a smell like melting plastic all that keeps above 2 or
3 seconds.After that I saw the 10 A fuse of the converter that has been burn.
Next step is that I was opened the charger and take a closer look inside of it and
what I saw it was the mellting plastic capsule around the varistor ...
Also I measure the Ohm between the power outlet and it gives about 41Ohm.
What I can do from this point and after...?If I m going to replace the varistor and
capacitor it will works?
Thank you in advance!!
  • mdd0204 Jan 22, 2009
    hey . after conecting the charger to 220V (by mistaken the 240w to 240v) i blew up the VD101 and replaced it . now after checking it with 1000w adopter its working .
    i saw the pag about how too modefai to 220v but iv got the p/n 630504b4 will it work ?
  • 66 Answers
Hi all,
I added another HowTo page for moding the DC18RA from 110V to 220V , you can find it here
Have fun and good luck
Posted on Jan 10, 2009
  • Avi Apr 12, 2010
    sorry for your lose
    In my
    mod page
    it says you might also need to replace the MOSFET
    this is not always necessary as some users reported it works w/o
    replacing it. In addition, did you replaced 1 or 2 capacitors ? I was
    experiencing the same issue and thus wrote 2 capacitors needs to be
    As for the cost, please note that someone is making a profit from you,
    it should not cost that much ;-(
    Hope this helps
...The adapter who I had buy it is incompatible because it uses an electronic circuit to control the thermic
energy depended on it by ohms device you choose to plug ...So I was lucky that day,because the circuits
beyond the varistor damage further than by voltage did not hapened!
I Changed the varistor with a new one from a dead pc power supply and replaced the capacitor with
a new 400volt 220uf and finally it works better than fine ...!!!So if anyone else want
buying a 110volt charger and make it uses with 220volt he can follow 2 ways:
Buy a simple transformer 220volt - 110volt - NO electronic adapter 220volt- 110volt !!!- it will be a
little big and heavy for external use ...OR do the modifications
as I done following the instructions from this very remarkable site !!!
Thank you..!!!
Posted on Jan 09, 2009
  • 3 Answers
I purchased a new capacitor, varister, fuse and a new plug and carefully soldered in the new parts. I connected a battery and with a long extension lead stood back. As soon as i flicked the switch a tiny puff of smoke and a small pop came from the charger. I have spent hours trying to work out what went wrong. $40 in parts and it destroyed a perfectly new battery. Big disapointment.
Posted on Aug 22, 2009
See below the submodel of your charger. If the submodel is T than you can't convert it by replacing only the high voltage capasitors. If it S type than the converting should work. The battery itself is ok. Only a little fuse inside is damaged. You can weld a bypass wire on it, else if you can get a new on to replace.
Can I get a European charger for the RCA Viking Pro I've bought in the States? We use 220V instead of 110V
use a travel converter most stores sell them they invert 220 to 110 or visa versa 110 to 220
Jul 29, 2017 | RCA Audio Players & Recorders
My charger is accidentaly connect into 220v and this is burn. im here in philippine. its this to repair and i use again...
Is this a 110Volt version that you plugged into 220v?
There is a ceramic Fuse inside the unit that might be blown. It is the first thing on the circuit board near the power cord connection.
Open the unit up and post a photo of any burned components ?
Jul 10, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Modifying the DC18RA from 220V to 110V. how?
Really, this is not something that can be changed easily, just buy a 110 charger...
Mar 14, 2011 | Makita 18V LXT Lithium - Ion Cordless...
I bougth reciprocating saw, model BJR 182Z and circle saw, BSS611Z while I was in the U.S.A.These tools use the 18 volt LXT Lithium-Ion battery BL 1830. I also bought this battery.However I am going to use...
Why can't you buy the 230 volt DC18RA charger in europe (amazon.europe country) and use it. I had the same issue yet i burned out the fuse in the 110 volt DC18RA charger because i plugged it into the wall just using an adaptor. Lesson learned. Therefore, my first solution was that i bought a converter from 220V-to 110 Volt. This showed me that my charger was done. So instead of getting another 110 volt charger sent here to Europe from Canada, I returned the converter and have on order a 230 volt input DC18RA charger from which has the same 7.2-18V output. I have been told this will work yet the fear, and I don't know why, is that it will burn out the batteries in a year or so. It is difficult getting specific information from Makita, but I hope it all works out. Best of Luck for you
Dec 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have the Makita DC18ra s charger for 110V. by mistake i insert it to 220and burn the fuse and a components as described on the borad VDR1 01 Do someone knew what is this components thank alon
yes you can fix it i have done 2 charges but white you are in there if you chance the large round capacitor to a 450v one you then can use the charger in 220 v you will have to increase the size of the voltage resistant diode to 240v (the vrd101 part in the charger) or by pass it with a straight bridge then the charger should work in 220v because the rest of the charger is exactly the same the parts will be around $10 ibought the parts from farnell
May 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita DC18RA charger conversion
You can't use the same capacity as it gives you a very
large and expansive capacitor.
I used the max. diameter of 30mm that could go into the PCB of the model I have and it is 470uF 400V
You'll need to replace another capacitor, see my mod page !
This works !
I added another HowTo page for modding the DC18RA from 110V to 220V , you can find it here
all the components details are in it
Jan 06, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
DC18RA from 110v to 220v
The varistor you have to change is the one that runs parallel on the current after the fuse, in my case it was easy to find as it was the one with the plastic hood on it.
I'm going to update the webpage with some new pictures that I hope would hetp to clarify it.
Nov 16, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Modifying the DC18RA from 110V to 220v
Hi there the solution for how to mod a DC18RA charger can be found here. The "how to" comes with pictures and descriptions and it should be easy to follow, and best of all it works :)
Jun 27, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 18v 120volt american charger to be used in australia
Don't go buying more stuff when you can fix the problem yourself without buying any converter. The modification required to do it is very easy and most people wont have any problem following it.
You can go to this webpage where a detailed walkthrough is given (with pictures):
Some of the post are in norwegian but the walkthrough is in english.
Good luck and happy moding :)
For those of you that have "blowed up" a makita charger 110v on a 220v, don't throw it away!
If you are lucky you have only blowed up the fuse and the varistor, which are easy to replace, and if you follow up the walkthrough you might even go all the way a mod the charger to 220v.
I know, I have already manage to "save" a blowed up charger.
May 16, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill Logo
2,069 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
