Question about Canon imageCLASS MF8180C All-In-One Laser Printer
"Supply Rec. Paper Tray : LTR"
We are getting this "Supply Rec. Paper Tray : LTR" read out on our machine. We've checked everything and even have unplugged our machine to reset it for 30 minutes and nothing what does this mean. There is nothing in the track and there is paper in the tray.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
I am getting flashing error messages 'Supply REC. Paper Tray: LTR' and 'Received in Memory'. There is no paper jam and there is paper loaded in the tray. I have also tried to manually feed paper. I have...
Hi there:
I had the same problem and it made me crazy. All you have to do is pull out the paper tray, pinch the very back wall of it (I think it has a blue button to pinch) and slide the very back of it forward so the paper is snug in the tray. Put the tray back in and it should go away. :)
Hope I helped........
Mar 09, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
Light under memory/alarm is flashing red. Window
if the error is change paper size also, under printer properties set the paper size i.e. A4, by default its ltr and these can cause problems.After that turn off and on.
Hope that helps.
If not, send more detailed description.
Aug 27, 2010 | Canon imageCLASS D320 Digital Copier
Supply rec. paper tray:ltr
1) unplug machine from power supply.
2) Under printer properties, select custom paper size and set it on A4 if you use A4.
3) Power on the machine and then try to print.
Hope that helped
Jun 29, 2010 | Canon imageCLASS D320 Digital Copier
Error message saying "supply rec. paper"
There is a small side tray on the right side of the machine,check if there are paper loaded in.
Jun 30, 2009 | Canon LaserClass 9000L Plain Paper Fax
Machine won't print, copy or receive a fax
With red button stop the copy, or switch off and on.
If you print on this unit make sure that you did choose a right format of paper (A4,A5,...)
You can change the format ap printer properties or preferences
May 21, 2009 | Canon imageCLASS® MF6550 Laser Printer
Supply Rec. Paper tray will not clear even with a whole ****
Ok try this - switch the machine off at the mains, empty the paper tray. Push the paper tray back in and switch on the machine with no paper in it. When it's finished warming up it should tell you the tray is empty. Then put paper in. This will usually clear it.
Jan 24, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
Alarm will not clear "Supply Rec. Paper Tray: LTR, their are no jams and the cartridge is installed properly. MF5550
Check paper size
If it is ok go to print job cancel and cancel all jobs
if the error comes while computer connected printing
before click ok go to peinter properties and change input paper size to A4 and out put as match paper size then click ok .
Mar 07, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Supply rec. paper Tray:LTR
Sorry i said he reset it, he actually cleaned the feed rollers and run a bypass to allign the feed drive unit, I am getting him back in so i will keep you all posted on the outcome
Feb 21, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Msg:supply rec paper
Ya, I had that same problem too; I was printing something that was over printing margins, and then i had the message "supply rec. paper......" on the lcd screen. I ended up fixing the problem by clearing/canceling all the documents i was printing on my computer, and clearing/canceling all the documents saved inside the MEMORY OF THE PRINTER (note the green light with the "memory, in use" which means it's probably still trying to print the document that's too big, so it wont print anything else). (<--- not sure if that was your problem, but it was mine)
Anyways, to clear the memory inside the printer, i pressed the "status monitor" button located to the left of the "B&W start" button, and then i scrolled over to "print status, select job to cancel" and canceled all jobs, and then once i canceled all jobs, the alarm disappeared, and it was fixed XD
Feb 13, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
and PLEASE HELP
Make sure you check both paper sources, the side tray going empty will cause your alarm to go on
Apr 25, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Canon imageCLASS  MF8180C All-In-One Laser Printer Logo
726 people viewed this question
old marine
old marine
