Question about Reddy Heater-70,000 BTU Kerosene w/T'stat
WONT FIRE we were in a flood this past June, I have a 70,000 reddy heater, it has always worked fine, it was very dirty after the flood, I power washed it off, drained the old fuel out of it,thinking it may have water in it, put clean fuel back in it, plug it in and I get nothing it wont fire, I can hear the motor running,just wont fire I am at a loss, need help from here, where is the plug? what should I do?
  • Anonymous Jan 25, 2009
    m150d has new plug also fuel not a problem but still will not fire up.
  • 27 Answers
Have you cleaned the air inlets? I have a older (1970's) reddy heater, occasionally it starts getting smokey or not firing at all. I open up where the air filter is and clean out the chamber with carb cleaner; gets the old girl firing up nice again.
Posted on Jan 23, 2009
Testimonial: "Thank You, it had internal problems, ended up throwing away, wasn't safe"
I have an r-50. It just won't turn on. It worked fine last winter
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 11, 2010 | Reddy Heater R70 Portable Forced Air Space...
Reddy Heater-50,000 won't fire, fan comes on for few seconds than shuts off
Here is a tip that I wrote that tells you how to troubleshoot a Torpedo or Reddy heater...
heatman101
Sep 17, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I have a Reddy Heater 70,000BTU without a thermostat. It will flare off and within a few seconds the fire goes out and then the it trips out. After a few tries it won't even flare off. What might be wrong?
hello. Your reddy heater is dirty and needs a good cleaning. Also, here are a few other possible reasons why it won't operate properly. Pressure not adjusted to 5.1 psi, dirty outlet filter, clogged inlet filter, bad or dirty photo cell, defective reset switch, pump going bad, dirty injector nozzle, dirty fuel filter, contaminated fuel. Check yours out and do what you can to address each area of concern. Regards, Joe
Jan 21, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
What will happen if I burn a diesel/ gas mix in a reddy heater 55000 multi fuel heater?
Hi, If the heater recommends kerosene or diesel only, and you mix gas into the situation, you will get an explosion and fire loosing not only the heater but most everything else.Unless the spec's say you can since it will use other fuels, gas would be one I would not use, mixed or not, like I say only if it says you can. At 70,000 B.T.U.s, as it says above, this Reddy heater burns hot anyway, and I don't want to put you in a dangerous situation by saying yes, go right ahead? So please check first, I would say no way. Good Luck, and Sincerely, Shastalaker7
Nov 21, 2009 | Reddy Heater R70 Portable Forced Air Space...
100,000 redi heater wont fire just blower fan runs
The igniter is most likely bad.Make sure the igniter is not working,and the pump for the fuel is working,one,or the other is not working,if it is the fuel,order a new pump kit,with impelar,and if it is the igniter,replace it with a new one.
Oct 21, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
RM 115 NO Fire
Hi
Read this from Reddy
http://www.reddyparts.com/pressure.htm
Feb 14, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater 55 wont Fire
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 03, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-70,000 BTU Kerosene w/T'stat Logo
265 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
