Question about Acer Aspire 5100 Notebook
I cant connect my laptop to my tv with vga cable?
  • raisa_irfan Jan 07, 2009
    and no it didnt work. i did everything but then my tv just said "format not supported". i think it might be bcuz my laptop is linux based. what to do now?
    yeah i know. n icud hear the audio but cudnt c any video??? maybe i have to do something with the laptop to get connected??? by the way my laptop is linux based!!!
    Sergeant:
  • 366 Answers
Yes you can.
remember you have to set your PC display settings and select the input in your TV.
Audio must be transferred via separate cable.
Let me know if you know where to config your display settings.
Posted on Jan 07, 2009
  • Pat Batta
    Pat Batta Jan 08, 2009
    some links for Linux environment:
    Link 1
    link 2
    Link 3
    Linux is the reason because your video card is managed in a complete different way, but I do not see why yous shouldn`t be able to config it
Cable to connect laptop to TV
VGA from the laptop to whatever the TV takes.
Mar 19, 2014 | Computers & Internet
Tip
How to Hook Up a Laptop to a LCD TV by VGA cable?
First of all check out does both the LCD tv and laptop both have vga cable input socket This is the most important step, as it will allow you to buy the right equipment.
VGA cable is the standard 15-pin connection that you would use to connect a monitor to a PC or laptop. Use a VGA cable to connect your laptop's VGA output with the television's VGA input. Use separate audio connection with mini-jack (3.5 mm) to RCA adapter.
Turn on your devices. Once you've made the connections, turn devices on. Switch your TV to the input mode that corresponds with the input you used to connect your laptop, and you should now view your laptop on your LCD TV.
This will help.Good luck.
on Mar 08, 2010 | Computers & Internet
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Mar 14, 2013 | HP Pavilion Computers & Internet
How do i hook my compaq preario cq56 laptop to my hitachi hd plasma tv
The laptop looks like it has an external VGA port only and without knowing what model of Hitachi tv it is. It is quite possible the tv may have a VGA input in which case a standard VGA cable will allow you to connect the laptop to the tv. Otherwise you will need one of the following depending on what connections the tv has:
1. VGA to HDMI cable: http://www.amazon.com/Video-Cable-Black-Support-Necessary/dp/B002TUC64W/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355697785&sr=1-1&keywords=vga+to+hdmi+cable
2. VGA to RGB cable: http://www.amazon.com/eForCity-Premium-Component-Cable-Black/dp/B0012SPNII/ref=sr_1_1?s=electronics&ie=UTF8&qid=1355697879&sr=1-1&keywords=vga+to+rgb+cable
If you do not have an HDMI input, you will also need to get an audio cable as well. Standard mini-stereo audio cables should allow you to connect the laptop to the tv.
Dec 16, 2012 | Compaq Computers & Internet
Connect laptop to tv
To connect a laptop with a Sanyo TV, the TV must have VGA cable connection. VGA cable picture
If the TV is not equipped with a VGA cable, it can not be be a laptop and a TV connection.
Jan 07, 2012 | Toshiba Satellite A665-S6086 16-Inch...
Cant connect my acer aspire 5334 to sony bravia tv
Your laptop and Sony Bravia LCD tv has the VGA connector.
It looks like ..
Connect your laptop to Tv using vga cable.
Thanks for using FixYa.
May 23, 2011 | Computers & Internet
I HAVE CONNECTED MY ACER ASPIRE PC TO MY SAMSUNG LCDTV USING A VGA CABLE , THE PICTURE IS THERE , BUT I CANT GET ANY SOUND ?
The VGA cable only supplies video data to the LCD TV. Connect a sound cable from the audio out from the Acer PC to the audio input on the LCD TV to get sound from the LCD TV's speakers.
Dec 14, 2010 | Computers & Internet
How connec my lap top to my tv?
if your laptop has vga output and your tv has vga input then connect vga output to vga input on the tv with a VGA cable that simple. With no real information onverning model numbers - i cant tell you what else you need to do.
Jun 30, 2009 | LG 42LC2D 42 in. LCD HDTV
Connecting my laptop to my Cello mtv21d flat screen LCD TV
Depending on the laptop, the usual way to do this is to connect the VGA cable to the laptop and the TV. Select the VGA input from the television remote and press FN+F4 to switch the image to the television set.
Mar 29, 2008 | Televison & Video
Acer Aspire 5100 Notebook Logo
78 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
