Question about Sony DAV-BC150 System
Is it possible to use the speaker system on a different DVD player?
I am looking to replace my DVD player, the DAV-BC150 because the 5 disc changer gets stuck too much. I want to know what to look for on products to know that I can connect the 5 speaker system to the new DVD player for the tv. I hope I asked that right. Thanks!
  • 1 more comment
  • Chris Dietsch May 30, 2007
    Sounds like you totally understand me.
    If I get a cheap DVD player like you said, I use the yellow component cable to my tv. Then how do I get the sound through my 5 speaker system again? I don't know which way I'd attach it. Id connect the cables from the audio out on the new DVD player into the old one somehow?
  • Anonymous Mar 21, 2014
    will daewoo 5900 dvd player work for 5.1 speakers system ?
I believe I understand what you're asking here. To the best of my knowledge sony puts a special type of connector on the reciever end of the speaker wire which will probably not be compatible with any other reciever brand. Depending on the age of your system, the speakers may not even be compatible with the new Sony models. Wait...there's good news though. Whatever reciever/DVD player you decide on, there will surely be speaker outputs and if you snip of the Sony connector and strip the wire a bit, you shouldn't have a problem. A couple of other things to consider though... A conventional standalone DVD player may not have outputs for five speakers and a sub. That sounds more like a dedicated reciever. I have a crazy suggestion but you might save yourself some money and trouble. -If you are satisfied with the speaker portion of your current system, buy a cheap DVD player, run the video out to the TV, the audio out to the AUX audio in on your current system and use it for sound only. Hope something in here helps.
Posted on May 30, 2007
  • Joshua Tilton May 31, 2007
    You're almost there. Use the yellow RCA cable from the video out on the new DVD player to video in on the TV.
    Now on the new DVD player there should be two audio out ports (most likely right beside the yellow video output that you will have connected to the TV...probably red and white if they're typical RCA outputs). Using the other two prongs of the RCA cable (the red and white) run it from the audio out of the new DVD player to the red and white audio in ports on the old system.
    There are probably multiple inputs for aux, cd, etc. Just be sure that whatever ports you plug into, that you set the old system to that function (ex. aux) and you should be good to go.
    Feel free to repost with any further questions.
    Hope this helps.
SOURCE:
My older Sony Home Theatre/DVD player sometimes will not output any sound.
Sony eSupport - DAV-HDX500 - Support
https://esupport.sony.com/.../model-home.pl?...DAVH...
Sony CorporationHCD-HDX500 - DVD/Receiver Component for Home Theater System ... How to troubleshoot if there is no sound or intermittent sound from the speakers.
[PDF]DVD Home Theatre System - Sony
https://docs.sony.com/release/DAVHDX500.pdf
Sony CorporationDVD Home Theatre. System. Operating Instructions. DAV-HDX500/HDX501W ... not expressly approved in this manual could void your authority to operate this ...
Sony DAV-HDX500 No Sound : hometheater - Reddit
https://www.reddit.com/r/.../3nenei/sony_davhdx500_no_sound/
RedditOct 4, 2015 - My Sony DAV-HDX500 only plays sound when using the built in dvd player. ... Sony system you have does have a digital optical input so that's ...
Jan 10, 2016 | Sony DAV-HDX500 System
Remote is working ,but DVD player button is not working and I could not eject my disc from dvd player.
DVD player drawers are generally driven by a small rubber belt that either falls off or breaks. Easily fixed by just looking inside the unit and replacing the inexpensive belt.
Oct 10, 2015 | Sony Dav-dz640k DVD Multisystem Home...
My speakers have no sound and I dont have a remote to turn off rec mode. Can I do it without a remote
Buy a new multi disc dvd player, or get a sony dvd home theater system DAV-HDW589W, it holds up to 5 discs
Aug 16, 2012 | Pioneer XV-HTD520 Multi-disc DVD Player
How do I connect a new dvd player to Sony DAVS500?
If DAV-S500 have Input then hook new dvd player there and you can listen surround sound too.
Jan 02, 2009 | Sony DAV-S300 System
My dvd player (Sony dav s500 system) kept freezing and now always says"disc is dirty" and wont play. Can I connect another dvd player to the system? How would I connect the 6 speaker cables into the new...
Umm, this isn't just a DVD player, It.s an amplifyer too. Just leave the speaker cables alone, plug in the new dvd player into the "video2" jack, yellow cable onlt. Then,plug the audio cables into the video2 jacs (the red and white ones). Select "video2" on the SonyDAVS300 and "video2" on the tv. Insert the dvd into the new player and enjoy. It's screwy but it works through the amp and sends the picture to the tv.
SPEAKER WIRE CONNECTORS
You need 5 Cord (wires) Connection to attache all speakers.
You can have all 5 cords in one package or each cord individually at Sony Accessories.
Please write model number DAV-FR1 in search box to get result on above web page.
Details of wires required.
182724411 1 BAG = 5 CORDS approx $43
179146811 CORD, CONNECTION approx $10.30
Nov 10, 2008 | Sony DAV-FC8 System
LG home 5 disc dvd changer
try to clean the dvd player it could be the lens that is having a hardtime reading the disk and it causing the noise
Jul 21, 2008 | LG LXD5230 System
NO DISC ERROR on DAV-BC150
Given how close to the warranty termination the problem occurred, I would call Sony and request warranty service. You should speak to a supervisor who will have the power to grant that concession. If that fails, open up the unit and clean the lens using a cotton swab and alcohol. That may resolve it. Otherwise, the optics assembly will need to be replaced. I think that model uses a KHS-240. I can look that up if it comes to that though.
Keep us posted.
Dan
Apr 16, 2008 | Sony DAV-BC150 System
NO DISC ERROR
Sounds like a dirty or failed laser or DVD mechanism /drive.
Try a DVD/CD lens cleaner (must say both). If you can, try wet & dry version with alcohol based cleaner - Alsop are a good brand.
If this doesn't work, the drive has likely failed. Its unlikely to be economical to repair - but you could always connect a cheap DVD player to the Sony system - the sony system can then continue to provide surround sound audio, whilst the cheap DVD player plays the discs!
Otherwise - sell the system as separate parts (speakers, remote, cables, DVD player) as someone is bound to be desparate for the speaker set on its own to complete a system and will often pay more!
Jan 01, 2008 | Sony DAV-S500 System
5 DVD disc changer doesn't open
are you using discs with labels that you out on your self? I had a similar problem before and my label peeled off in the player causing it to get stuck., you might just have to take it apart, and get the label out.
Dec 27, 2006 | Sony DAV-C450 System
Sony DAV-BC150 System Logo
187 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
