Question about RCA F32648 32" TV
RCA F32648 32" TV DVD Connection
I've connected a DVD using the video in source. I can't determine how to set the TV to be using that source rather than the coaxial cable for the videio and audio. Any suggestions?
My daughter is having the same problem with the same model tv.. I had a bit of trouble finding the manual for that tv at the RCA web-site --- but I did find it at Amazon.
The URL for the pdf version of the manual is:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000032746.pdf
Assuming you have the remote for the tv, there are instructions in the manual for setting up the relationship between the DVD player and the TV.
(The URL for the TV on Amazon is: http://www.amazon.com/RCA-F32648-32-TV/dp/B000050FZR The link to the manual is toward the bottom, in the Product Details section.)
Posted on Jan 25, 2009
I have a (i think 20 inch) rca truflat tv and i can't find the channel for video and dvd. the manue didn't help and i don't have the guide"
Press menu on your remote. Press "4" for channel and "4" for video input source. In this menu, you can toggle between s-video and regular video (yellow plug) input. The disadvantage is, if you're like me and you've got a DVD player and and VCR (or maybe a video game system) all hooked up to the same TV, you've got to go through the menu and switch the inputs to watch something else. I'm happy with my digital audio cable; I'll deal with yellow-plug video.
Oct 12, 2011 | RCA TruFlat 27F520T 27" TV
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
I have a 2006 RCA 52 inch rear projection TV and I am having trouble finding a HD cable that will fit my TV and the DVD player. Do you have any ideas?
Try another method,get the same result.Ur tv have a S-Video connection in ur tv?Use that the S- Video cable,and that connection.Than use the RCA Red,Yellow hook up for the audio.
Apr 29, 2010 | RCA HD52W58 52" TV
Rca 20F514TD blue screen
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 05, 2009 | RCA 20F514TD 20" TV
Blue screen. No audio or video through the cable hook up. RCA model #32V420T
Oct 25, 2009 | RCA 27F534T TV
I have an RCA F36676ET that has a broken cable connection. TV works fine with DVD player but satellite connection not recognized. Can the cable connection be replaced? Can I do it myself?
If you mean the cable connector is broken off, then yes, that can be replaced. A company called MCM Electronics sells replacement connectors, but the repair requires soldering skills. Incorrectly done, the repair attempt can create even more problems. I suspect your satellite receiver has A/V outputs like the DVD player. Why not connect the receiver the same way as the DVD player and forget about the cable connection? You'll get improved picture and sound that way. If the set has only a single set of A/V inputs, you can cheat and use "Y-adapters" available at Radio Shack to connect the two sources to the same jacks, or you can get an A/V switch to do it.
Dec 03, 2008 | RCA F36676ET 36" TV
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Sep 27, 2008 | Televison & Video
Sanyo TV
If I understand your posting/description right, you have:
1, a Sanyo TV with only 1 video input;
2. you have a DVD player with only video output; and
3. you have a VCR (which I will assume to be with both video input and output).
Your query, if I may clarify, is how to hook them up so that you need not connect/disconnect any video cable when you want to switch video source from either DVD or VCR.
If that is what you want, then connect:
a. audio/video OUT of your DVD to audio/video IN of the VCR;
b. audio/video OUT of your VCR to audio/video IN of the TV.
The above described connection would allow you to:
i. watch DVD movies on your TV (your VCR must be powered ON and set to Video INput, your TV must be powered ON & set to Video INput);
ii. watch tape movies from your VCR without disconnecting/connecting cables.
Additionally, this arrangement would allow you to record DVD movies in your VCR. Further, connecting your cable/aerial to the RF INput of your VCR would allow you to do the same with a TV/Cable program.
Incidentally, if one of your units (TV, VCR, DVD) would only have a single audio input, it is still possible since some models uses the white audio RCA connector as either left or mono, the red is right. You can also use a 2 female RCA to 1 RCA male adapter as shown below to joint the red/white audio.
Hope this be of some idea/help. Pls post back how things turned out or should you require additional information.
Good luck and kind regards.
Nov 19, 2007 | Sanyo DS32224 TV
RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Jun 25, 2006 | RCA F27645 27" TV
RCA F32648 32" TV Logo
231 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
