Question about Dell 924 All-in-One InkJet Printer
Paper doesn't feed right.
When I push start, the paper starts to go into the printer then it krinkles up like something is making it work one side only - I am not able to physically see the problem. This is for the Dell 924 printer.
  • 1 more comment
  • ohanni3 Jan 09, 2009
    it says paper jam for some reason but I can't see the jam.
    then the paper turns crooked and crinkles up like something's in the way, but I don't see what.
  • vwilliams1 Jan 26, 2009
    same problem.
  • sd7jd Jan 29, 2009
    Paper will not feed by itself. All-in-one 924.
    President:
  • 8,637 Answers
Normal 0 Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 24, 2009
Paper will not feed through printer
Probably something blocking the page. Look around in the printer (on the left side) and look for small pieces of paper. Sometimes using a thick piece to push through the printer works as it has more strength and can push out whatever is blocking it.
Apr 13, 2013 | Canon Office Equipment & Supplies
Lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
Canon MP470 - Paper starts to feed and twists then jams
i had the same problem, mine went into the printer fine and started to tilt. all i did was check the paper input slot and there was a necklace stuck in it, it was an easy fix after all, just had to pull it out. too bad there are more problems than it is worth tho, right now mine wont feed lol
Nov 11, 2008 | Canon imageCLASS D880 All-In-One Laser...
Paper jamming in rx585
Oct 13, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
LEXMARK 2470 PAPER FEEDER PROBLEM
Good luck....
Sep 13, 2008 | Office Equipment & Supplies
Printer paper feed error #3
Dear EATRUNNER,
This Error is related to PaperJAM now you can find the complete solution to related this Error ,on this URL:
http://support-au.canon.com.au/contents/AU/EN/8000647001.html
i'm 100% sure ,your problem is solved ,whenever you read this page properly.
Cheerup and Be Happy Always
Mar 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper will not feed properly/one side of paper not feeding in straight
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
542
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon MP160 all in one
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Yesterday someone replied to my problem, i tried it this morning and its fixed 1st time.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Jun 12, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Printer thinks there's no paper...but there is!
Sep 28, 2006 | Lexmark X85 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
74 people viewed this question
Top Dell Office Equipment & Supplies Experts
Prashant  Sharma
Prashant Sharma
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
