Question about Dell Latitude C600 Notebook
The laptop freezes after being on for a little while.
The laptop freezes up after being up for a little while, inorder to shut it down you have to push the power button until it finally turns off. reset won't work. This is not my laptop in is my friends She bought a reconditioned one and the warrenty is out of date. I also notice that the fan is clean but does not kick on (could this be the problem). everything inside is dust feel also.
Any help would be great. :)
  • SusanHanson Jan 07, 2009
    Processer works only when it feels like it. How would I replace it?
    Master:
  • 413 Answers
Does she have the power saving settings turned on? If so try to turn them off and see if the problem continues.
What do you mean by the fan does not kick on? If the fan is not working that could definately be part of if not all of the problem. The internal components need to be cooled efficiently in order for the computer to run. If any of the components have overheated this problem may require taking the computer to a technician to have them replaced.
As i was saying before try to turn the power saving off. This only helps when the computer is running off battery but it still causes more problems than it is worth.
Posted on Jan 07, 2009
  • Dan rogers
    Dan rogers Jan 21, 2009
    Unfortunately on most laptops you are not able to upgrade or replace the cpu. The cpu is built into the motherboard. If the processor is the problem you would be better off replacing the computer
    Sergeant:
    Champion:
  • 304 Answers
Well it can be possible the problem. the unit can get overheated because there was no airflow coming inside.
  • 679 Answers
Check processer fan; might be processer fan not working
  • rockfixya
    rockfixya Jan 07, 2009
    no need to replace processer; just change processer fan; its a typical process to change a processer fan.
    check out the following site for work on your problem>>
    http://www.directron.com/laptopdiy.html
    Thanks for giving me FixYa. and
    Thanks for using FixYa.
There are three green lights that stay on by the on button
try changing the memory cards first, my cards appeared to be good but after a little warm up the laptop would freeze up with the power and bottom three leds staying on then shutting down. i changed the memory out and the problem quit. i was using cheap memory cards.
Jan 22, 2011 | Dell Latitude D510 Notebook
Sl400 screen gone black. not able to shut it down. but i guess the system is working because i hear sounds.
Hi. Press the power buttong for 10 secs inorder for the system to shutdown. Take out the battery and unplugged the power adapter. Preass and hold the power button for 30 secs then put everything back in. Turn On the computer.
Oct 13, 2010 | Lenovo ThinkPad SL500 Notebook
How to log in safe mode in Vaio vpcw111xx?
Inorder to log into safe mode, you need to shut down the computer, then as soon as you turn on the computer, keep tapping the F8 key, you will get loads of options, select Safe Mode and hit Enter. its same with all the windows version.
Apr 29, 2010 | Sony VAIO VPCW111XX/W Netbook
Dell Latitude d600 series.The shut down after start-up
when your computer is freezes up then you download registry mechani it can improve your performance
Jun 28, 2009 | Dell Latitude D600 Notebook
Blackberry curve 8320 freezes
you should take it back and get a new one
Mar 18, 2009 | AT&T Blackberry Curve 8300 Smartphone
Toshiba satellite m40 booting problem.
Hi! It appears that possibly your hrad drive isn't set properly in the caddy? with the laptop powered down and disconnected locate the hard drive cover pop out the two locating screws and carefully move the caddy/hard drive BEWARE as the drive has fragile pins at the opposite end where you opened, hopefully little sliding pressure should remove. Check the retaining screws around the caddy (You'll need a small torx/philips screw driver for this) if all tight replace gently.
If you are uncertain I would recommend a technician check it for you.
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><
Dec 09, 2008 | Toshiba Satellite M40-S417TD Notebook
Duplicator freezes at 88%, or 98% when burnign and so discs are incomplete
check the amount of free space you have on your computer,if it too low this might be the cause of the problem, plus you might want to run defrag command
Apr 18, 2017 | ASUS Computers & Internet
Compaq presario laptop
full keyboard replacement is recommended as the brackets to place the keys are not sold
Mar 23, 2008 | Computers & Internet
Error Press OK! to continue
Hello johnny22, this is Enday inorder to solve your problem ..try this steps....uninstall your printer and then re-install the software again.... just see if its work...
If not just reply me inorder to give you another solution....
Jan 30, 2008 | HP Photosmart 3310 Printer
Dell Latitude C600 Notebook Logo
20 people viewed this question
Alun Cox
