Question about Whirlpool 24 in. DU948PWPQ Built-in Dishwasher
I have a whirlpool Dishwasher and it will not turn on?
It was running just fine and then just stopped in the middle of a cycle. It still has water in it now. None of the buttons will work at all but yet we checked and the power is fine so none of circuits are burnt out. What could be wrong with it? I don't want to pay a fortune for a repair man to come when a new dishwasher would cost $250 for a cheap new one. This one is about 4 years old. Thank you!
  • Linc459 Mar 26, 2009
    Same problem, tried the hold start button but nothing happened, held for at least 1 minute. No lights on any of the buttons either. Circut breaker was fine.
Keep the start button pressed in - the machine will empty out the water and cancel the cycle....then start over again.
Posted on Jan 08, 2009
My whirlpool dishwasher just stopped working the middle of the cycle with water still in the bottom and now nothing lights up or comes on and the water is just sitting in the bottom. Any suggestions?
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault and required to be replaced. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 04, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Dishwasher starts running for 2 minutes then stops
The first 2 minutes of the cycle is a pump out cycle followed by a brief pause then a water fill cycle.Make sure the water is getting to the water valve underneath. Check the water valve for power with a volt meter just after the pump out cycle. No power= bad timer or bad wire. Power = a bad water valve or no water present.
Jul 05, 2009 | Whirlpool Dishwashers
Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Jun 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Kenmore dishwasher stops midway through
http://fixitnow.com/wp/2006/03/29/whirlpool-kitchenaid-kenmore-dishwasher-poor-cleaning/
Here is a good page that can help you resolve this issue and buy the parts needed
Feb 14, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Bosch sgi45e12gb/22 dishwasher won't stop
hey you..I have a whirlpool dishwasher too that would not
stop the wash cycle...it would run for 2-3 hours,
and then run thru the whole wash cycle again!
so..I had a whirlpool factory trained repair man come to
the home. He ran a diagnostic and it was 100% good,
so he called Whirlpool headquarters spoke to them;
said...........every 250 hours the dishwasher will
RE-CALIBRATE itself! running for 4-4 1/2 hours
straight, in order to re-calibrate itself. I was
interupting this by opening the door before it had
run the full 4 -41/2 hours of it's self-maintenance program.
Perhaps that your dishwasher is doing too?
p.s. always make sure you get a repairman that
is factory trained in your specific brand, otherwise
you'll waste $$$ money with a repairman who doesn't
have access to the corporate tech's and direct access
to their parts/inventory.
good luck with your dishwasher!
mine is the whisper quiet with computer control on front
of the door.
Apr 11, 2008 | Dishwashers
After water turns on, nothing else happens
If you are hearing a humm noise after it stops filling, your motor is locked up.
Jan 04, 2008 | Dishwashers
Whirlpool 24 in. DU948PWPQ Built-in Dishwasher Logo
471 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
