Question about GE GSL22JFPBS Side by Side Refrigerator
Back of freezer ices up and the freezer
About 8 weeks ago, every few weeks ice started accumulating on the back of my freezer. When this happened, everything in the freezer thawed and my refrigerator temperature got warmer. I had been unplugging the unit, allowing the ice to melt and replugging to get it to work for a few more weeks. I have found that I can tell by the sound of the freezer when it's starting to fail again, so I've been unplugging and replugging the unit so it doesn't ice up.
Another note, iI had a handy man help with kitchen/dining room remodeling that claimed to know about electric. Prior to my refridgerator acting up, He put my refrigerator and microware on an extension cord to another breaker that also serviced muliple lights and power sockets.
  • lcarson315 Mar 17, 2009
    My model is GSL22JFRE
    The back of my freezer ices up, then the frig won't cool. I manually defrost it, but after a few days the same thing happens.
  • 1,543 Answers
You most likely have a burnt out defrost heater. The most common part number is WR51X10053, but if you comment back with your exact model number I can confirm that for you. To fix it, you will need to remove the shelves in the freezer so you can take the back wall out. Defrost all the coils by unplugging as you have, or use a hair blower. The defrost heater is along the very bottom of the coils and has a wire connected to each side of it.
Posted on Jan 07, 2009
We had a leak coming from the bottom of our Maytag Ice2o (MFX2571XEM) refrigerator - the freezer would accumulate a sheet of ice every week to two weeks and we would break it up.
well your picture did not show up here .if you have cleaned the drain tube out the problem should not reappear until it gets plugged again
Jun 24, 2015 | Maytag Refrigerators
Whirlpool model-ER2MHKXPL02 serial-ES3330121 water accumulates in fridge portion top shelf. recent problem did not occur til 1 month ago. no ice maker installed. Also some ice in freezer around vent to...
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Jul 06, 2008 | Whirlpool Refrigerators
Hi, I have an Electrolux French door fridge. the freezer keeps developing ice over the back panel and then the freezer shuts down. I have turned the whole unit off for 36 hrs to defrost and then turn it...
You have a defrost issue causing frost/ice accumulation on the back panel of the freezer and stopping air flow across the low side.
When this happens the air flow is stopped to the fresh food and its gets warmer by the day until it is finally defrosted. What is your model #???
Oct 17, 2013 | Electrolux Refrigerators
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
Water dripping inside KTLA22EMSS01
Your freezer actually cools your fridge. It sounds like you have ice build up in your freezer behind the back panel. You should be able to unscrew the back wall inside your freezer. A hair dryer should help defrost or keep it open for a few and use a screwdriver to remove the build up of ice. The ice has made its way down the vent and when it hits the fridge it is above 32 degrees so it is melting. Hope this helps. I manage rental properties and have had it happen on a few occasions.
Aug 16, 2012 | KitchenAid Refrigerators
The freezer is on the bottom of the fridge...and the bottom part of the freezer is forming a block of ice..just over 1 yr ago that i purchased the fridge. i tried moving things in the fridge forward so...
There is normally a "thing" that controls the auto defrost I had a freezer that started so it this out of the blue. Some how that "thing" got unplugged. It was in the freezer behind a panel in the back by the light.
May 28, 2017 | Maytag MBR2562HES Stainless Steel Bottom...
Ice machine will not even start the ice making process. can get water out of the door with good presure but no ice
You either have a bad ice maker or a bad water valve. It really depends on what your model # is and brand.
Mar 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
I bought a upright frigidaire model ffu2124dw7,serial# wb63943076.Bought it a year ago and I have found that within a short period of time there a substantial amount of ice build up on the cooling...
ice formation depends in part on how often and for how long door is open but also worthwhile checking the door seal with a slip of paper trapped between seal and cabinet
Sep 17, 2008 | Frigidaire Refrigerators
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
Bottom of freezer icing with thick sheet of ice
you have a froen drain thats why it is allways getting ice on the floor. you need to remove as much as you can then remove the back of the freezer so you can clear the drain pan and clear the drain. its not hard to do just you will have a lot of water on the bottom and your floor maybe. once you remove the ice from the pan have some very hot water and pour it in the pan utill the drain is free and the water go's down into the drip pan. shut the unit off untill tour done and be carefull around the coils. once its clear put the back on and plug the fridge back in. you will now have no more ice build up. make sure there is no food back there that can block the drain either. its a god time to clean the freezer out
Aug 10, 2007 | Zanussi ZEBF250W Bottom Freezer...
GE GSL22JFPBS Side by Side Refrigerator Logo
221 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
