Question about Xerox Phaser 7700 Laser Printer
Phaser 7700 gx getting false errors all ove the printer
At power up printer is getting "cartridge 4 missing error" as well as "Tray 4 missing error." These will not clear no matter how many times you reset the printer. Occaisionally the printer will say all of the cartridges are missing as well as the lower left door is open. Again these will not clear. What could be causing this?
It might be somthing with the side cover not sitting right. If you feel comfortable doing it, remove and reseat the right side cover. I had a similar problem and this fixed it.
Posted on Jun 25, 2007
Xerox 7700. Paper is jamming at lower tray and bypass tray. Will print one page fine but multiple pages it stars jamming
Hello. The Error 11, polygon motor failure is usually caused by the motor controller chip going bad on the mirror motor. We found some of the contorller chips and had them replaced. The refurbished laser units can be seen at: http://www.lpscomputer.com/p-3060-1-116-1110-00-laser-unit.aspx
Nov 18, 2010 | Xerox Phaser 7700 Laser Printer
XEROX PHASER 7700 ERROR 11
Error 11, laser unit polygon motor failure. If this fault reoccurs 3 times successively the 7700 . enter diagnostics and clear tech rep fault and clear this 09-380, 09-383.
Oct 26, 2009 | Xerox Phaser 7700 Laser Printer
Phaser 860 error"replace paper tray "
Missing plug in tray on right side of tray. Top hole. Replacement plug can be gotten from xerox parts or inktechnologies.
Apr 03, 2009 | Xerox Phaser 7700 Laser Printer
Xerox phaser 7700 paper feed transparency errors
There is a Transparency sensor (called the OHP) which is part of the Registration Transport 116-1164-00
Clean it first. Or replace the whole assembly
Whit
Item, Inc.
Mar 24, 2009 | Xerox Phaser 7700DN Laser Printer
Xerox phaser 7700 error 11
man...
listen .. you is with error
go listen cradle of filth the heavy metal :)
good bye
see you later
Oct 16, 2008 | Office Equipment & Supplies
Phaser 7700 Error 54
You need to remove both the rear and top cover to access that fan easily.. There are some screws on the right side of the machine for that top cover. There are 4 or 5 in the back of the machine.You may have to remove the lower right cover to access the screws to the top.
They are interlocking covers, some dependant on removing others.
Sep 09, 2008 | Xerox Phaser 7700 Laser Printer
Hi, I have the Xerox Phaser 7700GX. I have a scrolling message that says 'cartridge 1,2,3,4 is missing' and tray 4 is missing. I've tried troubleshooting through Xerox'x support site - where I've switched...
That really sounds like corrupted software
Go to Xerox.com
Click "support and drivers"
Enter "phaser 7700" then click the orange "search"
Then "drivers and downloads"
Scroll to "firmware update"
Download it and follow the instructions to load your printer software.
That should correct your problem.
Apr 30, 2008 | Office Equipment & Supplies
Print cartridge "missing"--NOT
Problem:
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Door A not closed properly. - Open and close door A, then power cycle the printer and check for the error again.
2. The rails that the print cartridges slide in are misaligned or bent. - Remove the Transfer belt and all print drums, then check and re-align print drum rail guide. Then reassemble and verify proper operation.
3. Interlock actuator tab for the front door is broken off. - Check the interlock actuators on the front door if misaligned or broken then replace the front door, if they can be reconstructed then repair. Otherwise call for additional parts.
4. Cable connection to the Engine control board is not seated properly or fully. - Check all cable harness and wires to the Engine control board and make sure proper connection is made.
TROUBLESHOOTING TIPS AND HINTS:
Check all media trays, access doors, and front cover for proper closure and interlocks being disabled.
Apr 01, 2008 | Xerox Phaser 7700 Laser Printer
Ram Error message
Have you tried reseating the ram?
Dec 13, 2007 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7700 Laser Printer Logo
180 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
