Question about Logitech Curve Consumer Headphones
Trying to replace pad on earpiece
Pad and the over-ear loop came off -- I can't seem to get the foam cover to go back on. Thanks! aj
0 characters
1 Points
The thin black material covering the foam ear pads is flaking off and getting on face, ears and clothing. Can we get replacement pads? Dennis Christian
Yes there's a firm that might have them, you'll find it at the bottom of my tip on headphones. Just click my user name to find it.
Feb 21, 2011 | Labtec 835 Headphones
How do you open earpiece for troubleshooting no sound from right side and something rattling around
What you do is peel back the cusion of the ear pad. You might need to tear off the foam covering. You can glue it back on when your done with Bostick white glue. With the coverings gone you should see access screws.
Jan 30, 2011 | Samson CH700 Professional Headphones
My Motorola S305 stereo bluetooth headphones' foam pads on one of the ears is falling off. I've tried using something like a credit card to pinch the foam back into the game where it seems to be held in,...
Hey, this might be too late to help you, but I figured I'd share in case anyone else came across this while looking for help (as I did).
There's a small inner ring that the edge of the foam ear pads wraps around, but you can't really fit it under there while it's attached to the earpiece. The solution? I used something thin (specifically a nail file) to remove this "ring". It actually seems designed to pop on and off. I was then able to easily wrap the foam ear pad around the ring, then re-attach the ring to the rest of the earpiece.
Hope that helps!
Sep 28, 2010 | Motorola Stereo Bluetooth Headphones
I've noticed that replacement inner foam(that covers the speakers) and earpads are available for my Sennheiser HD 570 Headphones; how do i get the old ones off? Thanks
The ear padding is attached to and held in place by a plastic ring that fits into the speaker mount. Gently pull the ear padding outward so you can see the ring, then slip a flathead screwdriver or other object in (just a bit, you don't want to poke the speaker inside). Gently pry up , sliding your pry-bar along, and the pad should pop out quite easily.
Sep 19, 2010 | Sennheiser HD 570 Consumer Headphones
Opening bose on-ear headphone speaker's cup
Apparently there are screws hidden in the small foam ring covering the plastic (not the earcushion). Try it removing the foam and tell me how it goes!
May 02, 2010 | Bose in-ear headphones - Black with...
Fabric ear covers failing on my Koss headphones.
Try their limited lifetime warranty for resolution:
Apr 21, 2010 | Koss UR-30 Professional Headphones
Need earpad replacements for Optimus Pro-100 Wireless headphones
Just flip the headphone pad inside out on the Optimus Pro 100 wireless headphones.
Find the 3 screws on each headphone speaker, you have to push the existing cover back, but you'll find them. Remove the 3 screws. Be careful of the speaker wire that will be attached to the cover plate that has the ear pad on it. Also, look carefully at how the components are assembled inside the headphone, as you might disturb their setting. They are easy to return to their proper place if they move.
Gently remove the ear pad, turn it inside out and you will have a new covered ear pad. GENTLY, re-install ear pad onto speaker plate, be careful not to break the speaker wire that is attached. I found a little flat screwdriver helps to pull the edge of the pad over the plate. The ear pad is actually quite strong and can take some abuse, but don't pull the speaker wires loose.
After you have the cover back on, find the screw holes and put the 3 screws back in. Presto, a little cleanup on any loose pieces of covering from the original side and your done for another couple years or so.
Feb 26, 2010 | Headphones
Replacement foam for Beyerdynamic DT 531 Consumer Headphones
I have the same problem with a pair of Fostex Headphones. I have taken them apart and I have removed the rubber type ring that the foam fits over.
I am going to order a cheap pair of thin foam Headphone ear covers from Ebay. (They are available in various sizes) and stick the foam to the ring and follow that
by sticking the ring back in. Should work if the foam is thin enough. What do you think?
Nov 27, 2008 | Beyerdynamic DT 531 Consumer Headphones
Logitech Curve Consumer Headphones Logo
21 people viewed this question
Top Logitech Headphones Experts
Ml Howard
Ml Howard
Level 1 Expert
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Logitech Headphone Expert? Answer questions, earn points and help others
