Question about Tilia FoodSaver V2240
Foodsaver V2440 won't vacuum air out
The motor sounds great, but nothing else is happening. Last week it vacuumed , but would not ever stop and seal....I'm wondering if it just needs a couple of new foam gaskets?
Thanks.
  • 4 more comments
  • MELKNOX Jan 13, 2009
    WOULD NOT VACUUM THE BAG
  • Kathleen Hopkins
    Kathleen Hopkins Jan 17, 2009
    Mine vacuums sometimes for an extended period of time and then seals, sometimes it just vaccums and doesn't seal. I took the foam seal out and turned it around and it seems to help somewhat.
  • Anonymous Jan 17, 2009
    I have the same problem on an older one (VAC 800) and it's definitely the gasket on mine. I pulled it out and it was warped in a few places. My only problem is finding one now!
  • gt236 Jan 13, 2013
    If there is any sort of wrinkle in that open edge it won't stop sealing, or is even a slight bit of whatever you are sealing is over that top edge it won't work either.
  • Anonymous Mar 17, 2014
    Vacuum motor only hums/no sucking, remaining on first indicator light only, does not progress nor seals. Seals only if manually activated. Already tried soaking/moistening lower gasket with no results. Was a real workhorse until 2014. Thanks
  • Lee Eismann Jan 03, 2017
    See my comment below on lubricating both the upper and lower gaskets with food-grade silicone grease.
    New Friend:
You need new replacement gasket, to get one, visit amazon FoodSaver Vacuum Sealer Upper Gasket Assembly T910 00075. I hope this was helpful. cheers Foodsaver V2440 won't vacuum air out - foodsaver-v2440-vacuum-air-out-uh3jsoynacgcqh0wcsujgpyu-3-0.jpg
Posted on Nov 25, 2014
    You should NEVER have to replace your gaskets if you maintain them every few years with food-grade silicone grease. See my post below from 2010.
  • 5 Answers
If your FoodSaver is more than a couple years old, the gaskets have probably gotten compressed. Especially if you use it often or store it with the lid in "latched" position.
FoodSaver's website has replacement gaskets, $3 each, but it's hard to match the right gasket with the V2440. I called and got confirmation: it's this one. http://www.foodsaver.com/Product.aspx?id=r&cid=0&pid=294
Same gasket, upper and lower, even though it's listed as "Upper" on the Web page. You can also call them at 877-777-8042 and order Part # T910-00075.
Meanwhile, I've had good luck with soaking the old gaskets in warm water for a few minutes, then letting them air-dry. It seems to restore their sealing power for a day or two at most, but that's enough for me to vac up my weekly freezer groceries.
Posted on Jul 14, 2009
----------------This works great for OLD SEALS-------------------
Take your seals out.
Rinse.
Ring excess water out.
Put moist seals in place.
VACUUM HAS RETURNED!
Posted on Aug 18, 2011
    You should NEVER have to replace your gaskets if you maintain them every few years with food-grade silicone grease. See my post below from 2010. Water will dry out quickly - grease will last for years!
I held gasket over steam. Compressed areas expanded restoring gasket to original condition. Problem solved. Be careful, steam burns! Do not to put hands directly over steam. Tea kettle works well for this.
Posted on Jan 19, 2010
  • kittredgesw Apr 21, 2011
    My foodsaver was leaking through the attachment port for the jar sealer. If you hold your finger over that port it would vacuum good. It seems like the ball check valve is leaking.
    Novelist:
  • 88 Answers
The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
  • 1 more comment
  • wm9099 Nov 20, 2010
    The Silicone Grease worked great for me. I picked it up from Amazon for about $8.
    My Foodsaver vacuumed fine, but would never seal. I found that if I pushed really hard on the cover, it sometimes worked. Then I found this Fixya forum, bought the grease, and lathered up the bottom and top gaskets. My foodsaver is working as good as new. I don't know how long the grease will last on the gasket, but the 5 minutes it takes to apply it won't be a problem in the future.
    Thanks to all that posted here!
  • Lee Eismann Jan 15, 2013
    Is the vacuum pump motor working when you close the lid and select a VACUUM option? If not, there is a warning in the Foodsaver's documentation about not getting liquid sucked into the device? If the vacuum pump is active but not vacuuming, then your seals are likely faulty.
    Here it is 2017 and I just had to re-grease my Foodsaver's gaskets again as they had dried out after about 3 years. My Foodsaver is now working as good as new again, and it is now over 10 years old.
The phone # listed for Jarden still is valid, was able to get the upper and lower gaskets for my V2440 Food Saver from them. Thanks for the info.
Posted on Sep 18, 2010
  • Phurt Sep 18, 2010
    Try wiping the gaskets to see if they are free of dust or crumbs. This help me, I also ordered new gaskets as my unit was getting older and I was sure this would help. The number for Jarden solutions number is 1-800-777-5452 and I was able to get new gaskets for my model V2440.
Instead of silicon grease you can just use vegetable glycerin. You can get it in almost any supermarket for a couple of bucks. I actually just use the Rosewater & Glycerin that I have on hand. It's nice since it just feels like water but has the glycerin in it that preserves the gaskets. Fixes the issue for a couple of months at a time, even in the desert conditions I live in.
Posted on Feb 26, 2012
    The application of food grade silicone grease will last for a couple of years because it does not evaporate like a water and glycerin solution. And silicone grease can be used everywhere around the house, like faucet and hose o-rings.
    I just re-greased my gaskets with food-grade silicone grease after 3 years! I now have a brand new unit that is actually over 10 years old.
    New Friend:
The pumps do wear out. But its not the piston. It's the reed valve. It gets compressed for so long the reeds stay open.
Posted on Nov 28, 2014
    New Friend:
Mine may have (months ago) gotten some water in it. Could thishave stopped it from working?
Posted on Jan 11, 2013
I seriously thought the pump had just gotten worn out because of a lot of use. I greased the gaskets and it works like new again. Thank you for the advice. It saved me from having to buy a new one!
Posted on Nov 10, 2011
Door to my foodsaver is stuck on one side. It's shut. How can I release it? Is there a release button anywhere?
Trouble with Food Saver Brand - Survival Podcast
thesurvivalpodcast.com > ... > Food Preps > Processing Food For Storage
Aug 15, 2010 - 17 posts - ‎13 authors
We have been using our Food Saver Vacuum sealer we bought ... connects somehow got stuck open and therefore the bags would not ..... I've had the FoodSaver V3840 for about 10 months now and thus far it has been great.Missing: door
FoodSaver Repair - YouTube
? 8:22
https://www.youtube.com/watch?v=jguFiF0Rouw
May 21, 2014 - Uploaded by Kelly Kimble
Repair a FoodSaver that isn't drawing out air anymore. In this case, its ... Vacuum Sealer Troubleshooting - Duration: 10:25. katzcradul 52,345 views. 10:25 ... How to Food Saver Lemon Juice or Other Liquids - Duration: 4:56.
[PDF]Use and Care Manual - Home Depot
Jan 25, 2016 | FoodSaver Vacuum Food Sealer - V3840
Why is my Foodsaver V2440 motor noisy while vacuuming bags?
This is normal it means that its just pumping air out of the bag but if it gets too loud and its not pumping air out of the bag then you might need it looked at soon
Jul 12, 2014 | FoodSaver V2440 Advanced Design Vacuum...
Foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Jun 03, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
Doesnt vacuum all the air out
Your Product Manual for the Tilia Foodsaver Food Sealer Vacuum V2240 is available here:
http://www.foodsaver.com/Manuals/MANUALS/T000-32030_44_65900646.PDF
Please review all the Tips for Successful Vacuum Packaging. You may find some pointers that will you remove all the air.
Mar 26, 2011 | Tilia FoodSaver V2240
Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Dolphin Dive Center
May 17, 2010 | Tilia FoodSaver V2240
Foodsaver V2490 will vacuum but will not automatically stop and seal. Can you help
I experienced the very same problem. Pulled out the two foam seals, rinsed them under a cold water tap, wiped off with a tea towel, reinserted,
Nov 17, 2009 | Tilia FoodSaver VAC420
Foodsaver vac1050 wont stop runing go to 3 bars thats it
Dolphin Dive Center
Aug 12, 2009 | Tilia Foodsaver V835 Vacuum Sealer
Tilia FoodSaver V2240 Logo
30,882 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Tim Doolittle
Tim Doolittle
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
