Question about Coleman 850-870 Single-Speed Blender
Blendar makes clicking noise and does not run
I have charged unit and made sure blades are no binding.
Also I cannot find my owners manual to trouble shoot nor canI find a manual on this site.
Thanks,
Paul
  • paragonconce Mar 24, 2009
    i have the same problem.... cant find a manual
Blades won't turn when cup is on
check to see if shaft is turning when cup is off if it is somthung is binding it
Sep 24, 2012 | Oster 6804 16 Speed Blender
High pitched noise with use
The problem was the seal was worn, allowing liquid to seep past into the top blade shaft bearing washing out the grease and ruining the bearing. The "noise" you heard was the bearing running without any lubrication. Both bearings and the seal needed to be replaced but I have not found a source for purchasing these. Vita-Mix Company does not sell parts, they sell units (outrageously priced units)!
Sep 03, 2012 | Vitamix 5000 Work Top Blender
Ninja blender blade wont turn with food in container.
make sure blade is pressed tightly onto shaft... should click into indent. if not then you need a new blade piece.- stripped
Aug 18, 2012 | Blenders
Blender seems to run right until you put glass jar on.runs very slow.
Disassemble the base from the jar, and check the placement of the gasket. Reassembly, with the jar upside down is gasket, blades, then base. While disassembled, rotate the blades by hand just to make sure that they aren't in a bind. Replace if defective.
--W/D--
Mar 06, 2011 | Hamilton Beach 50754 WaveStation 10 Speed...
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Kitchen Aid Blender - blade not rotating
You will definitely need to change the clutch blade i.e. the black rubber rotating bit. Chaging it on the base unit may be difficult, I would check with your local Kitcheaid repairer for spare parts and repair advice.
Also check the clutch blade on the jug itself.
Apr 01, 2009 | KitchenAid Blenders
Blade doesn't spin freely
Here's the parts order form from Waring:
http://www.waringproducts.com/ret/parts/
Once you receive the parts, unscrew the collar from the bottom of the jar, and the old gasket and blade assembly will pop out - sometimes you have to peel the gasket apart from blender jar, but not always.
-Tha Mp3 Doctor
Mar 26, 2009 | Waring MX1000R Blender
Dynamic mx91. noisy.
dynamic mx91, motor runs but blade doesn't spin, how do i disassemble the blade & shaft?
Feb 08, 2009 | Dynamic MX91 Handheld Blender
Cuisinart CBT-500 blender won't work
(0) unplug unit (1) Remove the bottom 4 screws, cover plate and motor shield ( 2) unhook the white motor wire from its binding clip ( 3) locate the plastic sleeve with the fuseable link (4) cut the sleeve and test for continuity between points on either side of link with ohmmeter (5) if no continuity, clip out fuseable link and and solder the white wire back together (6) cover with tape (7) rebind to other wires (8) replace bottom and check. This worked for me.
Apr 13, 2008 | Cuisinart CBT-500 SmartPower Premier Work...
Osterizer Blender
You can replace the Osterizer "Standard Blade Assembly" (which includes a new rubber gasket) without buying a new and expensive glass jar. See http://www.householdappliance.com/blenderparts.html or one of the other appliance repair parts websites. After 20 years of use, it's time for a new blade and bearing.
Feb 27, 2008 | Blenders
Coleman 850-870 Single-Speed Blender Logo
56 people viewed this question
Top Coleman Blenders Experts
eyecam
Are you a Coleman Blender Expert? Answer questions, earn points and help others
