Question about RCA 27F530T 27" TV
Unusable Signal MY RCA 27F530T will be fine for an hour or so (Utilizing all Video Inputs incl. Coax)then the screen will go to black and white. If I unhook the video jack or coax or RGB or S Video, or if I turn off the TV...when I turn it on again it reads "Unusable Signal" , but I can still hear the audio. Any input would be great! Thanks in advance.
  • Christian Martin May 30, 2007
    I found the part you are referring to except it is TDA6108JF. It has 9 pins, aluminum heat sink and is attached to the PCB on the aft portion of the tube. Is it possible that this is the faulty part?
    Sergeant:
  • 308 Answers
You may have IB001 going bad, it is RCA P/N 263568, and should have TDA6107q labeled on the IC which should consist of 9 pins soldered into the PC Board and attached to an aluminum heat sink. It is a video IC and could be going bad unless you have a defective solder connection somewhere causing this symptom.
Posted on May 29, 2007
Rca unusable signal
Your TV could be on the wrong input source. if your using red/white/yellow cables look for an inpout button or source or even TV/Video. your tV has many inputs on it and you can only acess them 1 at a time, this allows you to toggle through the input sources and when you get to the right on you'll have picture and sound
Sep 29, 2013 | RCA Televison & Video
Rca big sreen went black and white menue is still in color
Try using one of the other video input options, like AV inputs. If still have black and white picture, then the color processor is having issues. If now in color, then your tuner has issues detecting the chroma / luminance signal.
If you are using an external digital box, this may be the source of the problem as well. If you still have a VCR, connect the coax from VCR to the coax input on the TV, and play a tape. Tune the tv to channel 3 or 4. If in color, then your set top digital box is faulty.
Jun 25, 2010 | RCA Televison & Video
Unusable signal
video inputs do not have channels you must not have it on the right source. Turn your Wii on then change the input untill you find it.
Sep 08, 2009 | RCA F32648 32" TV
Error on screen showing 'unusable signal' - input probs
Make sure you have all the cables in the right places, best to disconnect everything and start from scratch. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | RCA HD52W58 52" TV
RCA HD52LP: Composite video inputs don't work
RCA Authorized service tech looked at it. He determined that the DM Module need to be replaced. The part alone costs $550 + labor. Since the HDMI and component video inputs seem to work, he suggested buying a VCR DVD combo with HDMI output which would be far less than repairing the tv itself. I'n researching the possibility of purchasing the part myself.
Jun 08, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Installation of wii
I had the same problem on a 32" rca crt. It worked fine, power was cut during electrical work and when it came back, "unusable signal." I went into the menu, then channel, then video input source. had to change it to the correct input "s-video in my case" Then it worked. GOOD LUCK!
Feb 14, 2009 | Nintendo Wii Console
Computer TV out with S Video
You can use the yellow RCA cable using an SVideo adaptor. When using dual displays make sure that display number 2 is adtive. To do that move the mouse to display 2 press the right mouse button and select active. Check extend desktop to the monitor to check the signal and press apply. Make sure you are using either an Svideo or RCA signal.
Sep 02, 2008 | RCA RT2380 System
Help rca 46inch
I have the same problem using HDMI cable, I was able to get it working using composite or RCA
cables. I still cant get it working on none of the 3 hdmi inputs
May 31, 2008 | RCA L42WD250 42 in. LCD HDTV
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Televison & Video
Unusable video signal
e-mail me or call me 520-248-4242 any time
Dec 11, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA 27F530T 27" TV Logo
172 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
