Question about Panasonic PT-AX200 LCD Projector
Panasonic PT-AX200 lamp problem
I have a Panasonic PT-AX200 projector. The projector is installed in a well ventilated space and plugged directly into a wall oulet (no power bar). The problem I have is at about an hour into a movie the picture will flash very bright for a split second. This happens 2 or 3 times, all within about a 10 minute period (an hour into the movie). Also, it seems that sometimes the brightness of the picture seems to "flicker". Any ideas?
  • 2 more comments
  • andyhighland Jan 22, 2009
    I've had my unit for about 2 months and it has started flickering. I have turned off the light harmonizer, turned off eco mode, but nothing seems to affect it. it just cycles back and forth between 2 brightness levels about every 5 seconds. Bright, dark, bright, dark...
  • darcy_strinh Feb 05, 2009
    The lamp in my projector has only about 10 hours of use, so the lamp life isn't the problem. Anyone else have any other ideas?
  • kel18105 Feb 06, 2009
    I have the PT-AE2000U with 550 hours on the lamp , I have the same lamp flicking issue also. Brightness for a 3-2 seconds then dark then bright again. Does anyone have a real answer to this problem?
  • tpatana Feb 13, 2009
    I have same problem, although the cycle is more like 5-10 minutes. Annoying still. Anyone called Panasonic about this? Did they fix it for warranty?
I also have, mine did this but switching the dynamic iris off solves it.
Posted on Jan 28, 2010
I have the same problem and it is usually when the screen is showing a lot of white space for a long period of time (when I surf the Internet) I switch to Game mode and it stops.
Posted on Nov 24, 2009
I have the same problem (cycling between 2 brightness levels). I contacted the shop and the salesman (who is an expert in home cinema installations etc) told me that it has to be the last hours of my lamp's life... I don't know yet, I'll find out soon though...
Posted on Feb 05, 2009
Why red light is on ?
Its the most common poblem with the ax 100-200 projector.Many a times only the ballast requires to be replaced.yet on may occasions both mainboard and ballast requires replacement. its best to confirm with a good known working ax200 and replace first the lamp, ballast and the mainboard.panasonic ax 200 lamps also have failed premature as per my experience.
May 04, 2014 | Panasonic PT-AX200U Projector
Tip
Panasonic TYLA1001 Lamp Reset Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66...
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Here are the steps to reset the Lamp Timer for your Panasonic Multimedia Projection HDTV:
  1. Plug your Television in.
  2. Press the POWER button on the TV or the remote control.
  3. Press and hold the VOL- button on the TV, while holding the 0 button on the remote control for at least 5 seconds.
  4. When the reset procedure is complete, a confirmation screen will appear.
  5. Release the buttons and the LAMP indicator will go out.
Download the TYLA1001 Replacement Lamp Installation Instruction guide here.
I hope that helps.
on Apr 11, 2010 | Panasonic TYLA1001 TYLA1001 Projector Lamp
Tip
Panasonic TYLA1001 Manual Lamp Replacement Instructions Models No. PT-52LCX66 /...
Are you missing the Installation Instructions for your Panasonic TYLA1001 Replacement Projector Lamp?
A digital, pdf version of the TYLA1001 Lamp Replacement Instructions can be downloaded from here.
Once installed, reset the lamp timer of your Panasonic Multimedia Projection HDTV by following these steps.
I hope that helps.
Service manual for panasonic pt ax 200e
Goto scribd it is free to view online ;)
May 04, 2012 | Panasonic PT-AX200 LCD Projector
What will I do to reset lamp timer for my Panasonic PT-AX200 model
Read very carefully this is the only solution to reset lamp timer
1. Connect the mains lead to the projector and a mains socket, and switch the MAIN POWER on. 2. Press the POWER button.
3. Press the MENU button to display the menu.
4. Select the OPTION menu and press the ENTER button.
5. Select LAMP RUNTIME.
6. Press and hold the ENTER button for approximately 3 seconds.
7. The confirmation screen will be displayed and select OK.
8. Press the POWER button to turn off for resetting the duration of the LAMP RUNTIME.
9. Next time when you POWER ON the projector the duration of time in LAMP RUNTIME is reset to "0 H".
Jan 06, 2011 | Panasonic PT-AX200 LCD Projector
Changed my projector lamp yesterday, it work for about 4hours and went on standby. its now on a stanby mode and all effort to switch it on has not been successful. Please help me
Hi!
Is your projector connected to a source? ( Computer, DVD, or any device) make sure the connection is tight/properly plug in so that the projector will recognize the device attach to it and override the standby mode.
Hope this helps, thanks for contacting Fixya. Please keep us posted of issue. Cheers!
Dec 09, 2010 | Panasonic PT-AX200 LCD Projector
I have a Panasonic PT-AX200 LCD Projector. It is mounted on the ceiling. I need to know how to focus the screen without climbing up to the machine itself to do it. Is there a way to find the focu using the...
I'm afraid, no remote option available to focus image of this projector and has to do manually. Check projector Menu and select Test Pattern for optimum focus and it would be one time job if projector and screen distance has not been changed.
I'm not sure about the advice regarding "color management" as it has nothing to do with focus.
User manual link is also broken and take you no where.
Aug 11, 2010 | Panasonic PT-AX200 LCD Projector
Panasonic projector TV PT-43LC14 has a light yellow splotch on the left hand of the screen. Can this be fixed?
yes and no. it is a burn spot on the light filter on the blue lcd panel due to excessive dust and heat. panasonic does not sell individual parts of the optical engine, so you'll have to replace the entire engine. to avoid it happening again or getting worse, keep the projector cool and dust free. use canned air to blow it out.
Nov 30, 2009 | Panasonic PT-AX200 LCD Projector
Last night, a message started appearing saying the lamp needed to be replaced on our Panasonic LCD TV. What is this and is it something we have to do? I think it's the Panasonic PT-AX200 LCD Projector, but...
the lamp is good for about 2000 hours. after this, the lamp may still work, but not as well or for very much longer. after you replace the lamp, you have to reset the lamp timer (in the menu settings).
Aug 10, 2009 | Panasonic PT-AX200 LCD Projector
Panasonic PT-AX200 LCD Projector Logo
1,934 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
