Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Fault code F-07 on the display
When code is shown the machine will not work. Can't find the manual. Any sugestions
  • Anonymous Apr 13, 2009
    fault code f-07 what does this mean ?
  • Hotpoint Master
  • 3,463 Answers
Error code F07 indicates the heater relay is stuck, this is not recommended as a D.I.Y repair, my advice would be to call an experienced engineer to look at it, as there may be other probs that have caused this to happen.
Plz rate my soution
Thanks.
Posted on Jan 07, 2009
What do I need to get error code as machine is not working
If your machine has a digital display and there is a associated fault with the machine then an error code will automatically be shown in the program window but if there is no known fault then no code will be shown. Some machines use a varying array of flashing lights or beeps to display a fault and with these machines you would need to count the bleeps or note which lights flashed and in what sequence. These fault codes only show when there is a fault with the machine
Mar 28, 2017 | Washing Machines
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/07 error code on...
The error F/07 is shown on the display due to Motor Control Unit Error in the washing machine. The motor speed is not getting detected by the control board in the machine or there is a confirm short in the motor control unit.
This will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
Hi i have a lg washing machine wft8061dd,can u please tell me why PE appear when it turn on
Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch. It is rare to see this error code on LG washers.
On non-display panel models this fault code can be shown by the lights for fuzzy, heating and speedy or super, normal and hold being lit or flashing.
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
Jun 13, 2016 | LG Washing Machines
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Fault code 68920-07
    That's not a fault code.
    After the fault code(s) in a particular module is shown (if there is any), the display for that module finishes with displaying the component's (speedometer, tach, etc.) serial number.
    Jan 13, 2012 | 2008 Harley Davidson FLTR Road Glide
    Hotpoint WD860 - Fault Code F-07
    F07 indicates heater relay stuck.
    You need to check the heater to see if it is faulty, and fit new one if it is.
    Please rate my solution.
    Thanks.
    Jul 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
    4e code
    I just checked the Samsung website - you can download the manuals if you've lost them (website below). Not sure what washing machine you have but a 4E on model J1043 (which is the machine I have) says to check the following:
    i_1.gif Make sure the source water faucet is turned on.
    i_1.gif Check the water pressure.
    http://downloadcenter.samsung.com/content/EM/200701/20070109165927703/EN/J1043-01986D_sub7_eng_050708.htm
    Hope this helps.
    Dec 26, 2008 | Samsung WF337AA Front Load Washer
    Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
    F-1 is a fault code.
    Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
    Oven control beeps & displays any F  code error (for example
    F11) - Electronic control has detected a fault condition. Press
    CLEAR/OFF to clear the display & stop beeping. Reprogram
    oven. If fault recurs, record fault number. Press CLEAR/OFF
    contact an authorized service agent.
    Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
    Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
    408 people viewed this question
    Top Hotpoint Washing Machines Experts
    vince
    Todd Arndt
    Todd Arndt
    puggy666
    Level 1 Expert
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
