Question about E-Machines emachines (emachinees) CD-ROM Drive
Cd rom drive won't open
When i push the eject button the drive flashes once and makes a noise like it's trying to read a disk and then stops, the light at the bottom of the drive then flashes rapidly 5 or 6 times and then nothing happens. Both drives do this (cd writer also)
Please get back with me so I can install my new software!
  • Anonymous Mar 23, 2014
    'please insert disk into drive E" and ejects
  • 47 Answers
I had the same problem i solved mine by using a knife and using the tip of the blade to push up and pull out on the drive while it tries to open and drive opened with out a hitch.. it turned out to be a gear problem with the drive.
Posted on Jan 09, 2009
How do I eject a disk from my dell model 1737 studio lap top(window vista) . It made noise are clicking sound when it went in.
Hello Reg,
The CD/DVD rom is tray type then use a pin to eject the tray. There is small hole in front of tray plate.
Insert the pin in the small home and press smoothly and the tray will eject .
If the CD/DVD rom is different type then use long steel V shape clip to pull the disc.
Apr 14, 2011 | Dell Studio 15 Laptop
My cd rom tray will not eject and the light is
have you manually tried to eject the disc tray? There's a little hole on there somewhere, stick an unbent paperclip or safety pin in it and push until the tray starts to come out, then pull the tray out with your fingers.
Once you've done that, push the button to allow the tray to automatically retract.
Jul 22, 2010 | Teac DW 28E CD-RW/DVD-ROM Burner
CD-ROM Drive has a driver problem (Dell XPS M1530)
Driver will be on Opperating System it is a Sony Product that is extemely common.
If the Hardware has failed... it can also give you that same error... bit misleading. I'm assuming the light in the front of the CD Rom is flashing when you push the eject button and of course the door opens. This all can be true and the CD Rom could still be bad.
Try to locate a replacement CD Rom to test... friend or the cost of a new one is about 45-50 dollars...
:D
Jan 03, 2010 | Dell XPS M1530 Laptop
My CD rom drive won't eject the cd on my Dell Studio Laptop. I press the eject button on the comp, and the click eject on the cd screen, and it makes a noise but nothing comes out.
You may have a cd jammed in your drive. Switch the computer off and on the front of the CD rom drive is a small hole, if you push a straightened paper clip quite hard into this hole it will open the drawer.
Nov 07, 2009 | Dell (0F146) Internal DVD Drive
Wont eject cd
there is a safety release in all disk drives take a paperclip and push it into the small hole on the face of the drive and the drive should pop open
May 12, 2009 | Toshiba (PA3352U2CD2) CD-RW/DVD-ROM...
The cd door does,nt open
Make sure you feel some resistance when pushing, also try by going to My Computer, righ-click the CDRom and select eject (in case the eject button is broken.
If you hear bad noises, you'll need to replace the CDRom
Mar 29, 2009 | E-Machines emachines (emachinees) CD-ROM...
Disk (CD) will not eject automatically nor play a CD. It make noise, (a clicking),trying to eject. In my computer, it will not show that the CD is in the drive.
Turn the power off before you try this. There's a small hole in front of most CD drives. You can straighten out a paper clip and try pushing it into the hole. It should go in about 1/4 to 1/2 inch and then stop. Press just a little harder and it may push open the tray and eject the CD. If there's not a CD in it, it may move it enough that it will reset itself. Once the tray is open, and the CD removed, you can power on your system. It should pull the CD tray back in. Once your system boots, try the eject button to see if it works.
Dec 02, 2008 | Everex Computers & Internet
Cd/dvd drive
You can see a hole located on the tray of the cd rom drive. Commonly seen beside the button to eject the cd out. Grab a small pin and push the hole and this should eject the tray. Close the tray again by pressing the button. Eject it using the button. If everything still failed, call up Dell to have the CD Rom Drive replaced.
Sep 19, 2008 | Dell Inspiron 710m Notebook
Dvd tray and cd tray won't open on hp pavillion a 250n
Did it work OK under XP Home ?
Did you do a clean install or Upgrade your sytem when you "upgraded" to XP Pro ?
Jun 18, 2008 | HP (176135-630) (176135630) Internal 48x...
CD Rom
Well...first lets make sure the drive still can physically open.
http://i36.photobucket.com/albums/e40/freddyhard/CD13.jpg
There in the picture will show you where the manual eject button is. Use a paperclip and push the button in the hole. Once the drive is open enough for you to pull the tray, go ahead and pull it as far as it will come out. It will stop, and it shouldn't come all they way unattached from the rest of the unit.
Go ahead and take any cd or dvds that was in the drive out and turn your computer back on.
Once into windows, push the regular eject button and the drive should close the door itself. Let it sit for a second or two, and try hitting the eject button again. 9 times out of 10, that usually fixes my drives.
Hope this helps!
Jan 15, 2008 | Memorex 32023252 Internal 52x CD-ROM Drive
Computers & Internet Logo
671 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
