Question about JVC COMPACT VHS-C CAMCORDER
JVC gr-axm310u tape eater
I bought the JVC gr-axm310u camcorder off ebay and it worked fine untill it started eating tapes. Cant seem to figure out what the prob could be?
You know what it could be a malfuntion in the circiut take it to future shop or something
Posted on Jan 17, 2009
I can't figure out how to download video from my JVC GR-D90U Camcorder to my computer through it's usb cable. It is a mini DV camcorder that uses mini video tapes.
From the JVC manual "This camcorder can transfer still images to a PC via USB". There is no mention of video transfer via USB so it seems it is not supported.
Sep 25, 2011 | JVC GR-D90U Camcorder
Camcorder eating tapes
Your problem is a plastic belt that drives take up and supply reel. Most likely, you will not be able to relace it by yourself.
Dec 02, 2009 | JVC GR-AXM17U Camcorder
Tape does not play
It is possible that the play back function is jammed. The other is the belt drive is broken. You dont have to use the store you bought it from there are many electronic stores that have their own techs. Spare parts for JVC are easy to source.
Jul 28, 2009 | JVC GRDX77 MiniDV Camcorder
HELP ME to repair JVC GR-SXM755U
try putting tape into it may be the switch that sense tape is stuck or out of order it shud not play without tape this i s abnormal let me know if can help u further
Feb 26, 2009 | JVC GR-SXM755 Camcorder
JVC GR-AX640u VHS-C Eating Tapes
The capten belt slipped from the motor.so remoce the mechanisum and fix with a new one.
Oct 20, 2008 | JVC COMPACT VHS-C CAMCORDER
JVC Gr-DVL300 Won't playback
The heads are probably dirty. First you can try to let a tape run through from start to end and see if it cleans the head. then try running in reverse play scan. Next try a head cleaner tape if you have not yet. If these things do not get your picture back you should take it to a repair shop, I do not recomend taking camcorders apart for cleaning at home. Full size VCR's are ok to clean your self with instructions but not camcorders because they are vary easy to damage worse without experiance and proper tools.
Jul 09, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
Tape eating
unit need to be cleaned or have parts replaced if they got bad enough.
only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
Feb 04, 2008 | JVC COMPACT VHS-C CAMCORDER
JVC compact VHS camcorder will not record.
Apparently this same problem exists on many different models. I have a JVC grd72u. I called JVC @ 800-252-5722. I selected the "Corrective Action Program" prompt from the automated attendent. I spoke to a customer service rep. They are aware of the problem and are fixing it for free, but only until 12/31/07. I suggest you call ASAP and get your name in the computer. If the problem is something besides the CCD sensor, they will call you with the estimate to repair.
Nov 03, 2007 | JVC COMPACT VHS-C CAMCORDER
No playback on JVC GR-D72
It souunds like the problem is in the Vid-PC connection. I suggest you start by downloading the latest version of whatever software you have used to capture and view.
Also - uninstall any hardware in the PC that is used to capture (just remove from system device list) and then restart the PC and let it detect and re-install.
If you don't know how to do these steps, then you'll need geek help.
Oct 28, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
JVC GR-D370 Mini DV Digital Camcorder
Usually when the recording is started it takes around 10 to 15 seconds for the camera to recognise and display the duration of remaining tape, if you feel there is a problem, try using different brand tape.
Mar 17, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Video Cameras Logo
114 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
