Question about KitchenAid KGSI901PBS Gas Kitchen Range
The off button does not shut off oven for kitchenaid kgsa906
I turn on the oven like normal, but when I'm done using it, I press the off button and nothing happens. To shut it off I actually have to press the "stop time button" to set the shut off a minute later than whatever time it is.
Any suggestions?
  • 1 more comment
  • sam little Jan 20, 2009
  • Anonymous Feb 12, 2009
    i have the same problem ,first time use it
  • Anonymous Apr 13, 2009
    I have had this happen 3 times (it just happend the 4th). I have a maintenance agreement with Sears, and they have to replace the front panel board each time. They said to try unplugging it (or shutting off the breaker) for 2 hours to reset the computer but that has never worked. Get it fixed, and sell it.
  • KitchenAid Master
  • 5,568 Answers
I would suggest that you both check with Kitchenaid (Whirlpool) to see if they have done some kind of extended warranty since this sounds like it may be a design flaw.
Posted on Feb 26, 2009
  • webjerry Nov 26, 2010
    Have the same Problem
How do you reset a KitchenAid dishwasher model: KUDE70FXSS4?
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there.
Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
Jan 02, 2013 | KitchenAid Dishwashers
I can't turn on my KitchenAid Superba dishwasher. I pushed Normal and Start, and the Normal light started flashing, but didn't turn on. Pushed Cancel and now both the Normal and Cancel are...
Did you try turning off the power and then connecting it again?
If still problem is there open the door. Press the following sequence of buttons HI Temp Scrub, Energy Saver Dry,HI Temp Scrub, Energy Saver Dry. Now close the dishwasher door and latch it too and press the cancel button. This must reset the dishwasher.
Aug 13, 2011 | KitchenAid 24 in. KUDU02FR Built-in...
I used the self cleaning, quick cycle. When cleaning completed the display panel light went off and the door is still locked. Cooking part of the gas stove still works. Could you help us...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Jan 05, 2011 | Ovens
I was cooking in my Kitchenaid oven and the door locked. It will not unlock
We had the same thing happen
Turn the oven breaker off, then let the oven cool completely. Turn breaker on, there will be an error code appear, push and hold the "bake" button for at least one minute until an error message appears, then press the off button.
This reset the latch on our oven
Nov 02, 2009 | KitchenAid Ovens
Kitchenaid superba 27 double oven clock - can't change the time!
I went to the website:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203177060.pdf
http://www.kitchenaid.com/custserv/service.jsp
from page 8
Turn the knob to the left until a tone is heard and "time" appears in the display window. The previously set time will appear in the display window.
Continue turning the time knob in either direction until the correct time of day appears in the display window
Press the START button to begin clock operation
Nov 17, 2008 | Ovens
Kitchenaid superba stove
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven. The Control Lock is preset off;
however, it can be enabled.
When the control is locked, only the TIMER SET/START and
TIMER CANCEL pads will function.
The Control Lock is preset unlocked, but can be locked.
Before locking, make sure the oven, the Timer and Timed Cooking
are off.
To Lock:
1.
Open the oven door.
2. Press and hold the number pad 3 CONTROL LOCK for 5
seconds.
A single tone will sound and “START?” will appear on the
display.
3. Press START. “CONTROL LOCK” and a picture of a lock will
appear on the display.
To Unlock:
1.
Open the oven door.
seconds.
A single tone will sound and “CONTROL LOCK” and a picture
of a lock will disappear from the display.
Sep 29, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
Oven does not turn off
I'm having the same problem with model KGRK806. There's asking for $221 for the control panel part and another $180 for labor.
** If you want to continue using don't unplug or flip the breaker. Instead set the cook duration for 1 minute and it will auto shut off.
Jan 14, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
KitchenAid KGSI901PBS Gas Kitchen Range Logo
952 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
