Infinity Cintre ME-940 Aluminium 2.5" USB 2.0 External Enclosure for 2.5" Hard Drive  Drive Case
Problem for Infinity Cintre ME-940 Aluminium 2.5" USB 2.0 External...
Problem with ME-940 enclosure
By carlosraul00 on May 29, 2007
I HAVE A ME-940 ENCLOSURE. CHIPSET CS8818 AND
TOSHIBA 40 GBYTE IDE HARD DISK.
IT WAS FUNCTIONING OK, BUT NOW, WHEN I CONNECT TO THE
USB PORT, THE DEVICE MANAGER RECOGNIZE DE DISK OK, BUT
THE WINDOWS EXPLORER DO NOT.
THE SIMBOL OF USB DISK APPEAR AT THE RIGHT CORNER OF
DE DESKTOP, BUT I CAN'T "SEE" THE DISK IN THE
EXPLORER.
THE TOSHIBA DISK IS OK. I TEST IT.
IT SEEM LIKE THE ENCLOSURE IS WRITE PROTECT OR LIKE
THAT. I CAN'T FORMAT IT.
Questions:
CAN I "RESET" THE CHIPSET WITH SOME ESPECIAL UTILITY?
DO YOU HAVE SOME UTILITY FOR THAT SITUATION?
HOW CAN I SOLVE THAT PROBLEM.
CAN YOU HELP ME?
THANKS
CARLOS RAUL
Best Solution
posted on Jul 09, 2007
Very Helpful)
Shang
Rank: Guide
Rating: 81%, 7 votes
This behavior occurs if you map a network drive to the first available drive letter after the drive letters for the local volumes and CD-ROM drives. When you install a new device or volume, Mount Manager, which assigns drive letters to volumes, does not recognize the mapped network drive and assigns the next available drive letter to the new device or volume. This causes a collision with the existing mapped network drive.
To prevent this issue from occurring, when you map a network drive, assign the highest available drive letter to the mapped network drive.
To work around this issue if the new volume appears in Disk Management, specify a different drive letter for the new device or volume. To do this, follow these steps:
1. Right-click My Computer, and then click Manage.
2. Under Computer Management (Local), click Disk Management.
3. In the list of drives in the right pane, right-click the new drive and then click Change Drive Letter and Path(s).
4. Click Change, and in the drop-down box, select a drive letter for the new drive that is not assigned to a mapped network drive.
5. Click OK, and then click OK again.
Was this helpful?
Yes
No
Popular Solutions for Infinity Cintre ME-940
Questions and Unsolved Problems for Infinity Cintre ME-940
Do you recommend Infinity Cintre ME-940 Aluminium 2.5" USB 2.0 External Enclosure for 2.5" Hard Drive (ME940U2) Drive Case?
Answer
Answer
when using my EasyCAP and Videostudio 8, it doesn't capture by video at all. It says : No signal or... (More)
Answer
the fab has died
Answer
What all do I have to remove in order to replace the passenger side headlamp assembly on a 2003... (More)
Answer
Do you have Mad Dog Multimedia - Roxio creator 8. XE Installation CD that i can buy?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Infinity Cintre ME-940...:
Top Drive Cas Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Drive Cas Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
