Question about Pioneer CDJ-1000 CD Player
Error 7001 The cd don´t go inside and the display show E-7001.
My bose CD player is not working my cd are stuck I don,t why
Good luck this should do it.
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Feb 08, 2015 | Bose Wave Radio
How to properly connect the channel Master antenna tuner to my TV so that I can connect an antenna to the tuner. I have the CM-7001. I'm connecting through the HDMI port on the tuner to the HDMI port
Confusing question! The CM-7001 is meant to be used for displays or monitors that have no means of connecting an antenna and don't have a built-in tuner. HDMI to HDMI would be the correct way and make sure you select the proper HDMI port. Or use the other video and audio cable connections.
Sep 03, 2014 | Channel Master CM-7001 ATSC Antenna and...
CD changer won't open. Mechanical Error on display
There is a small hole just above the door on most CD changers. Unwind a small paper clip and GENTLY push it into the hole. This should release the door, and let you look inside. Don't force it because you could damage it more than it is already.
Jun 15, 2012 | Yamaha GX-700 Shelf System
Cd player shows error "Mech"
MECH message means a "mechanical communication error", when display on your car cd player indicates that there is a problem with cd player that has do with the mechanism which is jammed up.
You need to open up the player and clean out the dust inside.
Good luck.
Oct 12, 2011 | 2007 Dodge Nitro R/T New Cars
Computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
Jul 02, 2009 | Gigabyte Computers & Internet
CD player Error 3
dear,
I have different experiance with the C.Dplayer ( error 3 ) , there is no need to remove it nor send it to the dealer ,all you have to do when you have `` Error 3 `` is to reset the C.D player , by recycling the power supply ,this can be done by disconnecting the main car battery power supply , you must also keep the battery disconnected for at least one hour . then connect the cables to the batteries ,when you start the C.D player you will hear some clicking sound ,and watch the numbers of the C.D`s in the display you will find all what is inside has been detected by the display .
and your C.D player is back to normal..
i discovered ths by chance , when I had this error in the past ,coincidently I had to replace the battery and after installing the new batteries ,i was suprised to see the player back to normal condition by its self.
Jun 02, 2009 | 2002 Lexus ES 300
Pioneer cdxfm128 12 disc changer
Err 11, Err 12, Err 14, Err 17
Dirt or a scratch on the disc stops the laser
beam from being able to focus.
Dirt or a scratch on the disc hinders the track
Clean or replace scratched disk.
There ya go, clean or replace the cd that is displayed.
Nov 15, 2008 | Car Audio & Video
I have a Kyocera c5020n with an occasional error "call service 7001: 0020988. It does clear if I power off/on.
This what it means (7001 is the error code: 0020988 is the page count) -
Toner motor 4 overcurrent detection
error (black toner)
• The engine controller PWB (KP-1054)
detected the overcurrent of toner
motor 4.
Defective toner
motor 4.
Jun 15, 2008 | Kyocera Office Equipment & Supplies
Error e-20. Doesn´t Work anything related to the Cd Players.
The system may need to reset. Unplugged the amp from the power source completely and let it rest for at least 5 minutes.
The illumination can only be controlled from the main remote. Adjust the prongs inside the remote and this should fix the issue.
Jul 28, 2007 | Nakamichi SoundSpace 9 CD Shelf System
Pioneer CDJ-1000 CD Player Logo
141 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
