Question about Canon PowerShot SD600 Digital Camera
Camera won't power up
I have a 2 yr old Canon PowerShot SD600 Digital Elph camera that when I press the power button nothing happens. I bought a new battery, charged it without success. This camera was never exposed to water, dropped or damaged in any way. Any suggestions?Thanks for any help you can provide
  • 2 more comments
  • Anonymous Feb 17, 2009
    camera will not power up, even with new battery.
  • Anonymous Feb 23, 2009
    camera will not power up. I know the battery is good.
  • ksullivan22 Mar 12, 2009
    I was using my camera and it was taking pictures it turned off suddenly leaving the lens still out but won't turn on. I just charged the battery and I know it is still good.
  • WILLIAMSE Mar 26, 2009
    CAN YOU USE ANY POWER CORD THAT TAKES 3 VOLTS TO CHARGE
Mine was the microswitch that tells the camera the battery / card door is closed. The tiny, cheap plastic protrusion that pushes on the switch broke off. Jam the switch with the end of a toothpick.
Posted on Feb 07, 2009
    Problem Solver:
  • 8 Answers
You might try cleaning the battery compartment of the camera to make sure that the contacts are not corroded.
Posted on Feb 03, 2009
I have a Canon PowerShot SD600 Digital Camera. The battery has a full charge but the camera will not power up. I press on and nothing happens. What do you recomend?Best RegardsNeil
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Oct 02, 2011 | Canon PowerShot SD600 Digital Camera
Camera won't connect to my computer
Windows update has changed your computer. From now on, use a card reader to download your pics.
Jul 16, 2010 | Canon PowerShot SD700 IS Digital ELPH /...
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon S230 Digital Elph has a distorted image in an awful pick.
See this link. If Canon determines that your problem is due to a faulty CCD (and the symptoms indicate that it is), they will repaire your camera at no cost, regardless of warranty status.
Jan 05, 2009 | Canon PowerShot SD600 Digital Camera
Canon sd 600 auto focus is not working
You should first check if the Lens of the Canon PowerShot SD630 Camera is clean,then check if it is the GPU problem.
Jul 22, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
My powershot sd600 elph, won't power up. brand new battery, why?
smtimes new battery also may have problem of low power....
u should try it another camera and see it works or not....
if again same problem comes then definately get damaged....
if it runs good in nother camera then i think there is still havin sm problem in urs camera....
show it to ur dealer for more infomation....
Jun 08, 2008 | Canon PowerShot SD600 Digital Camera
Digital camera lens makes noise when extruding
Manually rotating sensor rotor inside camera and cleaning gear fixed the Canon "lens error" for me.
I placed instructions with photo's here: http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/
Dec 18, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
379 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
