Question about HP Pavilion a305w (DM181AR) PC Desktop
My cxomputern turn the blue screen ups but then get goes to a black screen and thats all i get
  • Zain Ahmed May 11, 2010
    wat error does it show on the blue screen?
Normally this massage commes due to Less RAM in computer
or
due to bad sector on HDD
try to remove these problems
Posted on Jan 09, 2009
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
I have a compaq presario cq 60 to and when I turn it on it just sounds like it's going to start up and goes to a blank bluish black screen if I did it says the main screen and then it goes to that after I...
The blue screen typically would have a error message on it. I would recommend hitting the F8 key once a second after turning the computer on to get the windows diagnostic menu with choices such as safe mode. If you can select this then try a system restore point to when the computer was working properly. If you are unable to have it start up by hitting the F8 key then you either have a failing hard drive or a corrupt windows.
Dec 25, 2014 | Computers & Internet
Television comes on for a second and then screen turns black but tv still on
Does the OSD (on screen display) come up when you hit the menu button? If so try changing the input to the one you need.
Apr 04, 2012 | Televison & Video
Have a new balance 1400 treadmill. when i power it on the screen goes blue and it will not doing anything.
Does the screen turn on (blue) and then go black or does it stay blue? Mine has a similar problem where when the main power switch is flipped, it lights up, shows the initialization screen, then goes dark. Pressing any button on the console does nothing. I opened the console up and suspect one programmable microcontroller is bad. I'm going to see if I can get that part from FitnessQuest instead of replacing the whole board.
Aug 28, 2010 | New Balance 1400 Treadmill
Picture fades in and out to the color blue. sometimes entire picture is blue
id check the blue screen control first
its at the bottom of the set you will have to take the front panel off and behind it is another small black panel remove that one
and to select any function those controls need to be attached so slide that front panel to the left there and take you remote put the tv on video input
and there are sic controls on this little black screen control block
look for the screen controls and turn the blue one just slightly clockwise and you will see the blue screen will light up and you will have little arched lines turn the control back slowly till the lines disaper and the screen goes black
and then cycle the set off give it five mins or so and restart it and see if every thing returns and your video is being displayed then switch it back to your input and view and reassemble
Nov 19, 2009 | Sony KP-51WS500 51" Rear Projection...
Screen goes black nafter start up. What can I do?
You probably have some bad buffer boards as well as a bad Y-main bd and or a bad X-Main bd. Have a trained samsung tech troubleshoot the set.
Jul 02, 2009 | Samsung HP-S4253 Television
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Westinghouse LCM22W2 shows a display then turns off after half a second
I have the same problem and have traced it down to a potential power supply issue.  I bought mine at Best Buy in '06 and was told today that they will test the power supply for free.  It may range from $50.00 to $100.00 depending on where you can get it.  This does not include labor for those not qualified to work with electronics.  Hope this helps you.
Aug 13, 2008 | Westinghouse LCM-22w2 Television
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
HP Pavilion a305w (DM181AR) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
