Question about Vacuums
I bought a Eurika upright vacum (the boss whirlwind lite) it is pretty new, keeps shutting off before i am done vacuming, and the hose doesnt **** very well!!!
    Problem Solver:
  • 8 Answers
Your model mite have a divice that turns the motor off if it heats up if so take it to a repair shop and have them look at it
Posted on Jan 07, 2009
Where do you hook up hose
Years ago I used to sell and demo kirbys up to the G-5 model,I believe you have to sit in front of your vacume,raise the wheels as high as they can go and on the logo face tun the crank one way,this loosens the belt and give a little tug and the roller sucking chamber will drop.Pull the chamber away.,now take your hose and stick it over the shaft and lock it down with the wing nut and then you can use all your vacume attachments.UNLESS YOUR TALKING - vacume bag hose- this is just a simple twist and click on the vacume exhaust chamber. Now if your hose is unhooked in your vacume bag it self,you will have to get a new bag attachment or get a repair man to look at it.
Jan 08, 2012 | Kirby G6 Bagged Upright Vacuum
Vacum is fine just no suction on attachment hose how to unclug hose
Hi there, I see this problem pretty often because where the hose joins the machine proper there is a slight reduction in airway size. I have made a video to show you how to remove the hose so take a look at that. If you find a split in the hose you will need to buy a new DC07 hose because it will reduce suction ans cause blockages more frequently.
Feb 12, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
How do i change the belt in the boss whirlwind lite
Remove 4 screws on top and remove this cover. Belt and roller are easily accessable.
Jun 21, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
How do I change belt for Eureka Whirlwind Lite "Boss" model 450 A
Remove the 4 screws on the yellow top of the vacuum. The yellow plate will pop up exposing the belt and roller.
Jan 20, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
Vac hose clipping collar : one clip piece broken off need new collar
thats going to be a tough find. fantom parts are pretty much obsolite your best bet would be to either find a used one somewhere or just get creative and find a way to fix it so it can be used
Jan 02, 2010 | Fantom Vacums FM741 Twister Bagless...
Belt location
If you torn the macine over, at the bottom of the sweeper you will see the belt on on side. You have to take the bottom part apart and remove the brushes to replace the belt. I hope this helps.
Jan 21, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Belt broke
The belt number is 60957, There should be some screws that you remove from the bottom and the whole bottom nozzle will come apart, then you can change the belt.
Feb 27, 2008 | Eureka Boss SuperLite Bagless Upright...
Vacuums Logo
87 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
