Question about Health & Beauty
How do you clean the pipe on the rainmate?
In reference to previous question to my rainmate.
    Problem Solver:
  • 10 Answers
You use it for 10days and dispos it its right thing.
Posted on Jun 26, 2009
How do I clean the Rainmate?
Twist of stem from bottom, if excessive calcium or mineral deposits you can soak in vinegar. Keep hole in stem clean. Do not use harsh chemicals on any rainbow products it will compromise the materials. Vinegar should work.
Feb 03, 2016 | Rainbow Rainmate Air Purifier
Rainmate is not working, is there a warranty on it
Try to lubricate the fan bearings/bushings, it should help. If this does not help, check the repair price, or buy a new one
Mar 21, 2013 | Rainbow Rainmate Air Purifier
How much water should i use
I run mine day and night while home and clean and re-fill it every morning. I also use one of the room odor eliminators in my Rainmate. Fill the water one inch above the line about an inch off the bottom of the water container.
Aug 20, 2009 | Rainbow Rainmate Air Purifier
I need a Rainmate instruction manual
I have one and it isn't much, it's just a single sheet.
If you want tell me what you need to know and I'll try to help you by telling you what I've learned while trying to understand how to operate the one I have.
Feb 11, 2009 | Rainbow Rainmate Air Purifier
I was just wondering if the fragrances contain oil in them?
You simply remove the spindle and wash it out, and the spin wheel too if ot gets a build up. I use an antiseptic sort of smelling scent in mine and it helps capture dust. That is part of the build uop on the spindle. Simply turn it on the spin wheel and remove it and then wash it under hot water and let the hot water course through the spindle to clean it out.
Feb 09, 2009 | Rainbow Rainmate Air Purifier
Got Rainmate yesterday and either my house is REALLY clean or it isn't working
i had the same problem. The goo pulled from the air gums up the small orifice atthe bottom of the stem that sticks down into the water. If the water cannot be pulled up into the stem and expelled out towards the bowl at high speed, it cannot work. Take the upper, motor half off, unplug it hold the plate with one hand and twist the stem 1/4 turn and it comes right off. Clean the crud (yes, its your own skin cells) and the hole with warm water and soap. put it back together and refill with water and it works like new. this is now monthly maintenance for me
HTH
May 16, 2008 | Rainbow Rainmate Air Purifier
Rainmate not working?
Remove the tip by twisting 1/2 turn and it will come off! use a Q-tip and clean it out! Replace and should work just fine!!! From time to time it gets gummed up!
Mar 17, 2008 | Rainbow Rainmate Air Purifier
I can't take apart the Rainbow Rainmate to clean it.
The E series has a clear plastic window on each side that you remove to get to the screws, remove them and it will come apart. Some will have tabs instead of screws.
Mar 09, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Health & Beauty Logo
160 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
