Question about LG WD-1280FHD Front Load Washer
Help me to known
Hi my washing machine model WF-T8517TC is turn on awhile DE error code is showing so can u tell me which part is faulty and where do we can find this parts thanks
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
If you push in on the door does the error code go away? If so, then it may just need an adjustment. This is a door error code. Probably a losse or faulty door switch. If you are a do it yourself person you can try shimming out the door switch from the inside. You will need to take the top off of the machine to see if you have enougfh room to get your hand down to the switch where it is held on by 2 screws. If there is not enough room then you will have to also remove the door gasket, front control panel and then the front panel to get to it. It may be possible to put a few flat washers between the door switch and the front panel and then put the screws back in to pull the whole door switch assembly back a little bit (therby causing the door to shut tighter). If this does not stop the DE error then the door switch is bad and will need replaced. Your model number does not appear to be a US model, so I do not know the correct phone number for you to order the part if you need one. You will have to call LG customer service (for the country where this model was sold) to get the correct phone number if you need to purchase a part.
Posted on Jan 07, 2009
Lg turbodrum fuzzy logic 7.0 wf t700 showing error code "de" what that is mean? And how to fix it?
Try unplugging power, push and hold power button for 5 seconds, then plug back in. See if error code is gone.
Nov 05, 2017 | LG Washing Machines
Lg washing machine wf-sp950g de ( door error )
Hi Azlan.
de Door Error usually shows when the door lock either won't undo...OR The machine won't start after the door is closed.
Both these situations probably mean that the door 'Interlock' is faulty.
The interlock is the part of the door lock which prevents you from opening the door while the machine is working.
It's part of the electrical circuit and should only be serviced by a qualified technician.
Good luck
Nomess
Feb 04, 2015 | LG Washing Machines
Lg Fuzzy Logic 5.5kg Turbo Drum with I-sensor, Model WF-T552TH Washing machine goes through initial fill up, when changing to spin/wash works for 2 seconds, then stops spinning back and forth and shows dE...
There is a small magnet at the front of the lid that triggers the door error, mine was corroded and the lg people wanted $80 for a service fee.. Ha I went to my local hobby shop and got a small earth magnet and some super glue $1.50 later and she's fixed.. tadAaa.
May 11, 2011 | Washing Machines
Lg model number wf-t1246tp; error code dE appears on display. however, door is properly shut
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 09, 2011 | LG Washing Machines
I have problem with lg wf-t507 top loaded washing machine when i start it work for few seconds and than show DE .
'DE' on an LG normally stands for 'door error'. It is possible that the door catch/sensor either requires adjustment, if that is possible on your particular machine, or will require replacement.
Sorry but you will need to call your local service engineer ;-0(
Good luck,
John C
Feb 27, 2011 | Washing Machines
Error pada mesin cuci lg 6.5 g kode dE disebaban oleh apa?
m.cuci lg toplouding error DE. pada dasarnya pintu atas dilengkapi swich tapi kenapa model ini kok gak.terus gimana cara ngatasi door swich ini. mohon pencerahan
Jan 17, 2011 | LG Washing Machines
I am getting error DE in my washing machine, need solution for this. Kindly give me the service error code for LG WF-T7516HN top loader
HI there,
Well most of the times problem is in the door lock may be it's faulty. or it could be the door lack has failed/is failing or the control board, try closing the door properly and see if it works....... If further you have the same problem then you need to change the door lock (switch).
Good Luck
Thanks for using FixYa!!
Dec 03, 2010 | LG Washing Machines
My LG WF-TH700 washing Machines out with error dE.
Hello there:
This error code can sometimes also be shown as de or lid on the display. this error code is telling you that the lid switch may be faulty or that the ecu / electronic controle unit is bad and needs to be repaired so i would first have the lid switch checked and replaced if faulty also have the ecu checked and replaced if found bad .
also 1 thing you can try is to make sure the machine is empty and run a cycle like you would normally would and see if it reoccurs if it does than you will know it is one of the 2 that i mentioned but if it does not than you have a problem in the balancing or load sensor ok?
Hope this is very helpful for you
est regards Mike
Sep 26, 2010 | LG Washing Machines
LG WD-1280FHD Front Load Washer Logo
251 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
