Question about Car Audio & Video
Hey, I have a kicker amp model (zx350.4) I was playing my system when a girl spilled a lil beer on my trunk which ended up on the amp!! The amp started to fade; but still played intermittently.. And the Warning Light is now flashing when the amp is powered up?? Please tell me that it can be fixed??
    Scholar:
  • 96 Answers
If the damage is not terribly bad it can be fixed, the only way to know is take it to a repair facility.
Posted on Jan 07, 2009
I have 4 rsd65cs Phoenix gold 6.5 components 4ohm stable & 1 06S10L74 kicker I want to run it at 2ohm. A lil overpower is fine as I can always turn down.what is the best Option 5 channel amp? Thanks
sounds like you need to get a 2nd amp for the woofer, then bridge the two amps but be sure to adjust the output mode to lpf for your woofer and hpf for the 6.5s. hope this helps.
May 04, 2015 | Kicker Car Audio & Video
I have a kicker ix 500.4 hookd up to polk audio 6x9 and 6.5. if you play the system past about 25 volume the subs will keep playing but the speakers will cut out for a few seconds as if its hiting the
Make sure your frequency is no higher than 80 on the low and 120 on the high. Check speaker polarity with a AA battery(Speaker pops out when polarity is correct) Make sure the speaker crossovers are working properly. Check your ohm load when you connect the speakers together with a multimeter at the amp. Ohms that are too low = heat. See what your amp is rated for. After all that, turn the gain down all the way, turn up the volume to 25-28 and readjust the gains
Dec 07, 2013 | Kicker IX500.4 4-Channel 500 Watt Car...
Hey, I got a rf power 750s. I have a jvc kd-hdr20 h.u., and a kicker 07cvr154 sub. Install went smooth, but when I turned my car on I got power in @ the amp and a lil red light at rf badge, but nothing...
Check the RCA plugs where they mount to the board and make sure the shield ground pins are not broken. If in tact a regulator might have failed not allowing power to the op-amps.
Apr 20, 2017 | Rockford Fosgate Power 750S Car Audio...
Hey guys, I might be a girl but I can do some work on my lil 1993 restored 525i Instrument cluster lights just went out along with a parking light and can't figure out which fuse or relay to replace. I...
Front power distribution box is located in the left-hand rear corner of the engine compartment.
Fuse # 1 instrument cluster check control. Check fuses #4 ,5 &20. There is also a panel under the rear seat . Good luck.
Dec 21, 2010 | 1993 BMW 5 Series
No power to my kicker ZX 1000.1
sounds like you blew a fuse for the battery power supply to the amplifier
Mar 23, 2010 | Kicker ZX10001 Car Audio Amplifier
I think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Apr 09, 2009 | Kicker KX1200.1 Car Audio Amplifier
My amp turns off when i turn my speakers up
there is a safety feauture in the amp that shuts if off it is getting to much power from cd player outputs. all amps have this. some cd players also have this. unfortunately there is no way to get around this besides turning up the amp and turning down cd player
Mar 31, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker zx750.1 Amp in Protection Mode (Red LED)
My kicker amp zx1500.1 keep going in protection mode I unhooked the sub speak wires and put the ACR cords back in and it didn't go in protection mode what next
Mar 18, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Help me with my system
More information is required to start solving your problem. (ie. your make and model of "1500W amp", the voicecoil configuration of the kicker and Audiobahn 15's, and why you want to encorprate 2 crossovers in your system)
Seems as If you have a system without a plan.
Head unit?
More info necessary to give you the best use of your components.
Jan 14, 2009 | KEF Audio PSW 2150 Speaker
Car Audio & Video Logo
116 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
