Question about Technics SL-1210 Turntable
Dj decks-no sound
Hi, i have ministry of sound dj decks... i have connected the leads into the mixer (phono) and into my stereo (aux) which has a built in amp. it appears its all connected correctly, according to the manual, however i cannot get any sound either through the headphones or speakers???? Yet i can hear very, very, very faintly the song playing through the stylus/cartridge so i know it is playing! Please help i am very stuck!!!
Steph
  • 515 Answers
You didn't state if you purchased this used or new. If used, maybe the tonearm or the rca cables are bad. Or, if you set it up inccorectly.
Just to be sure...
TURNTABLE -> MIXER PHONO INPUT (CH1 or CH2) -> OUTPUT MIXER (MAIN OUT) -> STEREO INPUT (AUX IN or LINE IN).
Make sure you have the line selected properly on your receiver, and if you have a tape function, press the button in and out. Sometimes this will affect the sound. Now, check to see if your getting any signal to your mixer. Make sure the toggle switch on your mixer is set for PHONO and not LINE. Raise all volumes, including heapdhone, and see if you hear or see anything on the levels.
If all is good, but no signal going to mixer, then you might have a bad tonearm or RCA cables....
To check, disconnect the cartridge/headshell from your tonearm. Look inside the tonearm, and you'll see 4 gold plated prongs. Make sure they are all evenly protruding. Also make sure they are all a shiny. If you see any black substance on any of the prongs, they need to be cleaned. If any look like they are stuck, and not sticking out like the other ones, this would also cause an issue. This cannot be repaired. You can try to get the prong to come out, but if it does not work, you will have to replace the tonearm.
If everything with the tonearm looks good, then the issue might be the RCA cables. There is no easy way to check this, other than opening up the turntable. This is not easy, and I do not recommend.
Let me know how it turns out.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Posted on Jan 11, 2009
Amps ? stereo intergrated amps ?
Since the mixer has a line level output, yes you can use a home stereo for the "AMP". Use the AUX IN, TAPE IN or CD IN on the stereo and connect the speakers as you normally would.
Dan
Feb 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Piuoneer DJM600S feedback and cd input problems
Check List :
CD Deck 1 to Channel 1 CD Input
CD Deck 2 to Channel 2 CD Input
Mixer booth output to AMP's AUX or CD input.
use the BOOTH rather than the MASTER
even if you think you've done all these checks, check them again.
trust me I've been a DJ for 15 years & wired up **** loads of systems & still manage to ******* the wiring now & again lol.
you mite need to run an earth from your mixer to your amp.
One more thing, just out of interest you don't happen to have an amp with surround sound do you?
because if you do then switch the effects completely off this should sort it.
e-mail djtatty@hotmail.com
Jul 10, 2009 | Pioneer DJM-600 Silver Professional DJ...
Technic 1210 deck
Make sure your 2nd turntable is connected to the PHONO input of your DJ Mixer or Receiver. If you have it connected to LINE IN or AUX IN, the turntable will be very low, as this model requires a phono pre-amp to amplify it's signal.
If this is set up correctly, then you might want to check your cartridge. Can you swap the cartridges out to see if the problem remains on the same turntable, or if it switches to the other turntable. If it switches, then you know the problem is with the cartridges.
If that checks out ok, you might have an issue with the RCA cables or Tonearm or both. At this stage, I would suggest taking it to a service center for assistance.
- OPTiC
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 17, 2009 | Technics SL-1210 Turntable
Playing a ipod on a djm-500
Use a male Twin Phono to 3.5mm stereo jack plug lead. The two phono connectors need to be male, so that they can plug into the red & white line sockets at the back of the DJM 500.
Are available in any audio products store.
Regards
Rob
Jan 24, 2009 | Pioneer DJm500 Professional DJ Mixer...
Instruction manual for ministry of sound mixing decks
What are Ministry of Sound mixing decks? I am familiar with MOS, but was not aware they manufactured mixing decks?
Are you connecting these to a DJ mixer, or a Home Receiver?
If it's going through a home receiver, make sure you have them connected to the PHONO input on your receiver. If your receiver does not have a phono input, and you are connecting to the LINE IN or AUX IN section on the rear, you will not hear much. Most turntables require a pre-amplified signal, and only the PHONO input has this option. So, you will need to purchase a PHONO PRE-AMP, and connect your turntable to it, then connect the PHONO pre-amp to the LINE IN.
If you are connecting to a DJ mixer... same thing. Make sure you have them connected to the PHONO INPUT on the mixer. If you still don't get anything, then there might be something wrong with your mixer.
If you could clarify you exact set up, and the EXACT models, we can help you better.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Dec 27, 2008 | Technics SL-1210 Turntable
Connect turntables(technics SL1210MK5) to a mixer?
None. The cables are already attached to the turntable. They are hard wired to the unit. The red & White cable. Just connect to the PHONO INPUT on your DJ MIXER, and connect the thin ground wire to the GROUND terminal on the mixer. That's it your ready to go.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Dec 17, 2008 | Technics SL-1200MK2 Turntable
No sound out of deck
If you've already replaced the RCA /Phono cables, then the only other item that would cause this kind of problem is your tonearm, and it will need to be replaced.
- OPTiC
DJ Turntable Repair Expert
A DJ Pro Audio Co.
Dec 05, 2008 | Technics SL-1200 Turntable
No music
Where do you have the turntable connected? Is it going into a DJ Mixer, a Receiver, or a Power Amp?
No matter the unit, make sure you have it plugged into the PHONO INPUT connection on the rear. If your receiver/amp does not have this, then you will need a PHONO PRE-AMP - The turntable connects to the PHONO PRE-AMP, and the PRE-AMP connects to the LINE IN or AUX IN of your receiver.
If you are connected to the PHONO INPUT of your mixer/receiver/amp, then the problem might be one of the following on the turntable:
1) Tonearm
2) RCA Cables
3) Cartridge
There is no easy way to see which one of these is the culprit, it's just a matter of elimination.
But, you didn't provide much information. If you can be more specific as to how you have your turntable connected, what kind of cartridge your using, and whether or not, you've determined that the problem is indeed the turntable and not your mixer/receiver/amp, or even your speakers. This would help in determining what the issue might be.
- Davis
DJ Pro Audio
www.DJPROAUDIO.com
www.DJPROLAB.com
Jul 16, 2008 | Audio Players & Recorders
Very low volume!
If you're used to playing your vinyl through a hi-fi turntable (and not DJ turntables) then you're probably used to your turntable having a built-in amplifier. DJ decks don't have these and if you plug into 'line' it will come out very quiet. Try plugging into 'phono' if you have it, if not you'll need some extra amplification somewhere between the deck and the speakers (a mixer usually takes care of some of this before it goes into the main amp of the system). Hope this helps. Ad
Aug 06, 2007 | Sony PS-LX350H Turntable
Technics SL-1210 Turntable Logo
178 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
