Question about Dell OptiPlex GX280 PC Desktop
Cannot get 2 IDE devices to show in bios.
I have a dell optiplex, the primary HD is a Western Digital 160gb SataI also have a LG DVD/RW combo drive set to master on the IDE channel.
I recently attempted to add a 2nd ide maxtor HD and for the life of mecannot get both ide devices to show in the bios.. I've tried settingthe ide hd as both slave, master and cable select and the dvd drive the same to noavail, always one will show in bios but the other won't.. however bothide devices will show in windowsXP and work just fine.. being that Ineed my drives to be bootable I need them to show in the bios as well.
I've tried 2 different IDE cables now one being a brand new asus cable..
I'm curious as to whether it could be a power issue?
My power supply is 500W +3.3V +5V +12V -5V -12V +5VS8
28.0A 35A 25A 0.5A 0.8A 2.5A
I'm running currently:
1 WD JS1600 SATA HD
1 Maxtor 7200rpm IDE
1 LG DVD/RW COMBO
and most importantly, the energy hog PNY GEFORCE VERTA 9600GT
Other steps I've taken so far has been updating the bios, switching the cable and jumper settings to every possible combination, other then switching my Sata jumper settings which is OPT1 (I'm clueless on sata jumper settings).
The pc boots fine, although seems noticeably slower in boot and load times (although I had a virus or 2 recently that could be causing that) my main C: shows both in windows and bios, my dvd drive shows in both as well, my f: (ide hd) shows only in windows, even in disk management and works just fine.
Any advice would be highly appreciated as I've tried numerous forums, dell tech etc to no avail thus far. Cheers.
    Novelist:
    Champion:
  • 233 Answers
Does the computer have two IDE channels? If so set the Maxtor HDD as master on the primary channel and the DVD drive as master on the secondary channel. Also right click on My Computer, left click on Manage and left click on Disk Management and see if the drives show up there. Also check the boot order in BIOS.
Posted on Jan 07, 2009
HP Pavilion 7955 main HD failed; my data is on second drive (Maxtor ATA/EIDE) - still good. I want to install this as a second drive in Dell Optiplex 620 which has SATA main drive. The only IDE cables are...
Most IDE cables have THREE connectors:
* one to the motherboard
* one to the "primary" device (CD/DVD or disk-drive)
* one to the "secondary" device (disk-drive or CD/DVD)
If your IDE cable only has TWO connectors, buy a cable with THREE connectors, and connect your disk-drive to the third connector.
Mar 03, 2010 | Dell Optiplex GX260 Refurbished Intel...
Dell optiplex will not recognize hard drive
Is it SATA or IDE? Have you tried another cable? If it's IDE, have you checked the jumper settings (usually Cable Select is easiest)?
Feb 19, 2010 | Dell Optiplex GX60 PC Desktop
I have a dell optiplex, the primary HD is a Western Digital 160gb Sata I also have a LG DVD/RW combo drive set to master on the IDE channel. I recently attempted to add a 2nd ide maxtor HD and for the...
Hi there
When you into the bios settings choose default bios settings and save, reboot the machine and have a look in the bios again to see if the bios has picked the drive up
Good luck and kind regards
Jan 07, 2009 | Computers & Internet
CD/DVD-RW Drive
Any DVD Read writer will work
Jan 01, 2009 | Dell Dimension 3000 PC Desktop
My LG Combo is not working after i have installed another LG Dvd Writer
I am assuming they are both on the same ide cable. If so set both of the jumpers to CS (cable select) and try rebooting the machine.
If this doesnt work you might have the bios configured to say there is no drive on that ide channel location. If the first option doesnt work let me know and I might be able to help further
Feb 11, 2008 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Installing Hard Drive on Dell 8300
I am assuming that you are installing the Western Digital WD2500SB as a second Hard Disk in your Dell 8300. If it is connected along the same flat IDE cable as you old/original HD (Primary Master), you need to move the jumper in the WD for it to be as the Primary Slave. Instructions and illustrations are normally printed on the sticker atop the HD. If you are connecting it to the 2nd (Secondary) IDE, pls verify that it is not in conflict to any other device attached to it such as your CD/DVD. At any time, only 1 can be a master and the second device be the slave.
To verify that indeed your wiring/jumper and settings are correct, you can go to BIOS/CMOS setup immediately after powerup and determine if your PC has auto detected the new HD as well as the old/original HD & CD/DVD.
If for wahtever reason, the PC will not auto detect the new (Western Digital WD2500SB) HD and since it is new then, it should still be covered by the warranty and you can ask for a replacement.
If on the other handyou would want it to the the primary master and you would like to run your PC's OS on that new HD, you would need a CD installer/recovery to re-install the operating system.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Computers & Internet
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
LG COMBO DRIVE
Delete drive from device manager
Then change IDE cable and change the drive setting from master to slave or visa versa to re-initialize
Nov 23, 2007 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Dell OptiPlex GX280 PC Desktop Logo
284 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
