Question about Procom (177653) Utility Heater
ProCom blueflame heater pilot light difficult to light
I have a ProCom blueflame heater. There is a dial on top to operate it. The lighting instructions say to move the knob to "pilot", hold it in the depressed position, light the pilot and then you are supposed to be able to let up on the knob and the pilot stays lit and you can move it to the heating positions (low, med or high).
The first problem is getting the pilot to light. When a tank is initially connected, I have to hold the knob in the depressed position for perhaps 10 or 15 minutes to even have the pilot light up at all. Then, once it does light (with the knob continuing to be depressed), I have to hold the knob down for it to stay lit. If I let go, it immediately goes out and I have to repeat the process. If I hold the knob down, the pilot will stay on, but goes out immediately upon releasing the knob.
This continues again for 10 to 15 minutes. I have to continuously depress the knob and eventually 'get lucky' where I'll release the knob and the pilot light will stay on after which time, the heater appears to work flawlessly.
What causes the initial delay in even being able to light the pilot light? Is it just air in the line? Can anything be done? Then, once it lights (with the knob depressed), why doesn't it stay on immediately. Do I have a leak in the system? Bad thermocouple? Other issue?
This is only a problem on the initial startup. Once it's been running, I can move it back to the pilot position and the pilot will burn continuously as it should. Trying to understand what the problem could be so that I don't have to sit and depress the knob for 30 minutes every time I go to startup the heater. Seems it should work instantly or nearly instantly.
The main heater will not light unless the pilot light stays on and I can't move to low, med or high settings unless I release the knob from it's depressed pilot lighting position which I can't do until I've monkeyed with holding it down, releasing, relighting, etc... for a considerable amount of time.
Is there something I can try to do that might fix this problem or at least troubleshoot where the issue might be?
The igniter want light
Posted on Mar 29, 2011
Holding the button down enables gas to go to the pilot. When it lights you will see the flame touching two rod like devices. The small one is the igniter. The second one is a thermocouple. A thermocouple is a bimetalic device (2 disimilar metals) that when heated produce a small curren, this current in turns keeps the valve open for the gas to flow when you let go of the button. This is a safety feature. If the flame goes out on the pilot the thermocouiple cools and closed the valve shutting off the gas so you don't go boom! It sounds like the thermocouiple is bad or missaligned. If it is missaligned it will take longer to get hot enough to hold the valve open. Another thought would be the flame is not shooting out far enough (not enough gas pressure, clogged oriface on pilot(previous writer, leak but you get the idea. In my manual it had a picture of how the flame should look hitting the thermocouple. Good luck. My problem is I assumed that the regulator on my construction heater was the correct size. Maybe not. I have not had any luck getting the pilot to light at all. I hope I have not damaged the internal regulator.
Posted on Jan 17, 2009
You pilot ignator is plugged.I take a small wire and run it in the hole every year and I also Blow the heaters out real well with air.THis has always worked far me.I need a phone number or email address to Pro Com because i'm having problems with a new one i just bought and I can't find the papework.Could you pleas eif you have this info email it to me
Good Luck
Jay
jaycalk@yahoo.com
Posted on Jan 13, 2009
    New Friend:
The problem with the ProCom is the inlet pressure valve. The spring is too light, so when you turn the propane or gas valve on the rush of gas closes the valve and it won't release. To undo the issue, first you have to release the pressure against the valve. To do that you must break the line open with the gas turned off so the gas will escape allowing the piston to open. Tap lightly on the pipe going into the heater to guarentee it opens. Reconnect the pipes, inflate the lines with gas with shut-off closed.
Slowly crack open the shut-off valve slightly and start the lighting process, holding down the pilot button and striking the igniter. When the pilot starts, continue to hold down the pilot button down and slowly complete opening the shut-off valve. The pilot light should now stay on.
To possibly prevent this, shutoff the gas prior to extinguishing the pilot light and restart as described. If re-connecting propane, close the shut-off valve prior to turning the tank on, then starting as above.
Posted on Feb 14, 2016
    New Friend:
I have just purchased a procom ventless heater. The pilot would light after going thru normal start up. Returned new heater and received replacement. It won't start either. I replaced a ceramic with open flame.
Tried calling 877 number for help. Auto system said they would call back in 21 minutes. It's been over three hours and still no response
Posted on Dec 02, 2015
2 Suggested Answers
SOURCE: Procom Model SN400TYLA Thermocoupler bad, can't find part
try 18778865989
Posted on Oct 28, 2008
I have a procom ventless fireplace heater and the pilot light will not stay lit
Sounds lie you need to replace the bimetallic strip by the pilot light. If that is bad the main gas nor the pilot will stay on.
Jan 03, 2016 | Procom Heating & Cooling
Can't get pilot to light?
Use your warranty and contact service provider. usaprocom com
Nov 30, 2015 | Procom Heating & Cooling
Bought a new house that had a ProCom SSEB24RT in the fireplace. I tried lighting it this year and there's a spark but will not light. I've tried holding it in for 10 minutes to bleed t
Clean pilot generator and clean that very tiny fine hole in where that pilot light shoot out. If this don't work you that new pilot assembly kits.
Nov 24, 2014 | Procom Heating & Cooling
My blueflame gas heater won't stay lit
So we are talking about the same won't stay lit I will describe both ways. One is when you lift your fingers off the knob it goes out that instant which is probably the thermocouple needs replaced,look to make sure the tip of the thermocouple is in the flame of the pilot light first. The secound version of it is it goes out in a few minutes up to a few hours.The second version is most common.There is a part called a Thermocouple that is mounted next to the pilot light, it is around 3/16 of a inch diameter 1 to 2 inches long and should be mounted so the tip is in the flame of the pilot light. This is what tells the gas valve the pilot light is burning. If any dust ,cat hair ,dog fur what have you gets around the base of the hole the gas from this pilot light comes out of it will bend the gas, which move the flame so it does not hit the thermocouple like it should, this is below the flame so what ever is in there diverting the flame dose not burn up.A draft from a fan or door could do it also.I have used a procom ventless heater as my only heat for 7 years and have to blow it out twice a year. I bought a new thermocouple at the same time I bought the heater to have in the closet in case it went bad some night, it is still hanging there .Because it sucks air in from the bottom past the flame and out the top everything in the air gets burnt into a fine ash dust. So if you use compressed air to blow out your unit you might want to hold a wet towel up in front of it hoping a lot of that white powder dust will stick to it instead of flying around the room . My flame always looks so much better ,less orange and more blue after this .
Feb 10, 2014 | Procom Heating & Cooling
Procom pilot light wont light
Make sure the gas valve is on. The thermocouple may need to be cleaned in order for the pilot to stay lit.
Nov 26, 2013 | Procom Heating & Cooling
Burner won't light, pilot is burning just fine.
Once you get the pilot to light and stay lit did yall move the burner knob to the ON position? Is the temp knob all the way up?
Nov 27, 2011 | Procom Heating & Cooling
I have a PROCOM model ML300TBA, two years old. Here is my problem: Pilot lights fine. Burner lights fine. When I go back the next morning, often times it is out. Burner and pilot are out. It will...
You could try cleaning up the thermocouple with steel wool. Some manufacturers call this a flame generator as well. Any how make sure it is clean and positioned in the top center of the pilot light for best signal. This is only speculation as these are common problems that will arise on heaters in general. This also turns the gas to the burners and pilot light so thats why to start here first. Hope this helps you out.
Dec 23, 2010 | Procom ML300TBA Heater
The pilot on my Procom QL300TYLA will not light. It appears that no propane is getting to the pilot. I tried lighting the pilot and burner with a BBQ lighter but nothing. No propane getting to the unit....
sounds like you have a blocked pilot injector. normally part of the pilot head. if you can remove it , blow it out with compressed air but it must be removed from the pilot head. commonly known as a Pilot restrictor,Pilot spud or Pilot injector
Dec 15, 2010 | Procom QL300TYLA Heater
Pilot goes out!!
My manual shows three possibilities:  1) Insufficient fresh air available for combustion, so ODS kicks off gas flow 2) Low gas line pressure (should be between 11 and 14") or 3) ODS/Pilot is partially clogged.  Toll free number for ProCom is 877-886-5989.
Mar 09, 2008 | Procom ML300TBA Heater
Procom (177653) Utility Heater Logo
1,873 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
