Question about Acer AL1917W LCD Monitor
Acer LCD 1917 Monitor
How do you remove the base off of the monitor
AKAShadow
  • 32 Answers
SOURCE: how to remove the base from the monitor
Normally once the base is on its on forever. But you should see little clips that the base uses to latch onto the monitor. You can use a flathead screwdriver and bend the clips inward till the base pops off. Still will be hard though to remove the base. Seems they made that base to stay on.
Posted on Jul 19, 2007
Rifaa
  • 99 Answers
SOURCE: Drivers for the Acer LCD monitor X193W under Windows XP Pro.
try driver.com
Rifaa
Posted on Nov 09, 2008
  • 93 Answers
SOURCE: monitor driver for acer lcd x153w
go to the following link and u can download it there
http://support.acer-euro.com/drivers/downloads.html
Posted on Dec 29, 2008
  • 10865 Answers
SOURCE: HOW CAN I TAKE OUT THE MONITOR BASE FROM THE MONITOR ACER
remove the hinge cover, then remove the six screws you see there. Then the base slides out.
Posted on Feb 10, 2009
How to remove the stand of ACER LCD monitor H163HQ?
You should see a ***** located on the round base,just remove that with Philips(star) ***** driver and that`s it :)
Jul 31, 2014 | Acer X193W LCD Monitor
Hi! i got a acer al 1917 screen home from work, it seems fine when i start it and the acer startup screen comes up on display. but there it ends, when i plug it in, my cpu reacts on there is a screen...
Use a flashlight and shine on your screen. Look carefully is you still see the image on the screen. If you do, this is an indication that the monitor is still working, but the backlight has failed. A common solution with backlight-failures is to open the monitor, and look if you see any "swollen" capacitors (http://en.wikipedia.org/wiki/Capacitor_plague). If you see one you should replace it. Only open your monitor if you know what you're doing and have basic knowledge of electronics and soldering.
Mar 31, 2011 | Acer AL1917 LCD Monitor
How to remove the base
I have an AL2223W. It has 4 screws on the back that allows the stand to be removed. See if yours has that.
Jun 08, 2010 | Acer AL2016W 20" LCD Monitor
Is it possible to remove the monitor standfrom na Acer AL2016W monitor
Im under the impression you want to wall mount the monitor. Ive done this with a few monitors it should just unscrew and basically fall off? Have a look underneath the base for any screws they will be somewhere keep looking.
Oct 31, 2009 | Acer AL1916W 19" LCD Monitor
How to remove the base from the viewsonic vx2235wm monitor. I don't find any clip.
You have to remove the two snap-on plastic hinge covers to get to the base mounting screws.
Oct 04, 2009 | Acer AL1717 17" LCD Monitor
HOW CAN I TAKE OUT THE MONITOR BASE FROM THE MONITOR ACER AL2216W.
Feb 10, 2009 | Acer AL2216W LCD Monitor
Acer 1717 monitor- removal of base
At the base you want to remove - in order to pack the monitor - if you se at the rear left and right there are a tiny opening about 3 cm long,put inside a screw driver and it will open very easly the plastic cover.Then inside there are four screws,two on each side,remove them and the arm of the screen will be dis-attached.
Dec 21, 2008 | Acer Al2416WD LCD Monitor
How to remove the base from the monitor
For monitor or TV bases that have four clips, I found if two people each take two opposite clips, and use thumbs to push in the clips, we can pop the base off fairly easily. It is impossible with one person, since thumb and forefinger can't exert sufficient pressure on the clips.
Jul 18, 2007 | Acer AL1717 17" LCD Monitor
Acer AL1917W LCD Monitor Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
