My Sony kds-R60XBR1 went dark last night. The red stand-by light began blinking in intervals of 5 blinks Called Sony but unplugging the set and reset button attempts failed to start the set back up; It looks like some kind of a repair job to me. Any knowledge on this problem is greatly appreciated. Carl
  • 133 Answers
This is a ballast problem, it is what starts the lamp and keeps it lit, if you buy one and want me to walk you through how to replace it, please let me know, it isnt easy, but iv worked on about 300 of this exact model
Posted on Jan 09, 2009
Sony KDS-R60XBR1 No picture
Sounds like your light engine might have broken. Its around a $400 fix and I noticed Tri-State is having a sell on there about 341 its easy to replace it here is the link
http://www.tristatemodule.com/casearch.aspx?SearchTerm=kds-r60xbr1&asug=&view=grid&lang=en
May 14, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
Fuse replacement for KDS-R60XBR1
The info does not tell what is wrong---set has more than one fuse and if dead the set may still have lights on the front that light or blink (red one) in a specific sequence--5 blinks, pause and 5 blink etc.
A bit more info is needed to assist you.
Nov 08, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
Hi! GREAT site! We have a Sony SXRD KDS-R60XBR1 Projection TV and it stopped working last night... We are getting FIVE red blinks! What does that mean? Fans, bulbs.... ??? Thank you in advance for any...
5 blinks if for the ballast that powers the light. You can try changing the bulb first, if that doesn't fix it then I believ it will be your ballast. If you haven't changed the bulb before It could probably use one anyway, and you could keep the old for a spare.
Here are some more from sony on this.
According to Sony:
Red LED Flashing four(4) times
o Fan not plugged in
o Foreign object hitting blades
o CN2301 on ASU board not seated or connected
o ASU shield touching S1 board
Red LED Flashing five(5) times
o Interconnect harness from Lamp driver 5-pin to ASU 9-pin board not connected
o Lamp driver failure
o Bent pin on Lamp driver 5-pin connector
o DSU to C board harness not locked
o CN6501 on G board not seated or connected
o Lamp failure
Jan 29, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Have had to replace lamp twice in the last two years on my Sony KDS-R60XBR1 HDTV. Yesterday I ended up with the four blinking red lights showing on the Power/Standby indicator nothing by the lamp...
hi,
fist of all try to reset ur tv. to reset do the following.
Turn on the TV. While holding down the up arrow button on the remote control, press the POWER (on off switch) button on the TV. (The TV will turn itself off, then back on again.)
Release the up arrow button.
Dec 31, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Red light blinking 5 times. is a fan problem on a sony KDS-R60XBR1
here are the fans you need are you sure this is the problem
http://www.discount-merchant.com/SONY-Cooling-Fan-Set-Cooling-Fan-Set-p/1158984.htm
Sep 15, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
After a power failure I have 4 red blinks and tv
The fan has stopped most likey a problem with the AGU board
Jun 17, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Mar 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
KDS-R60XBR1 60" SXRD HDTV
I had the same problem if it is blinking 4 times like I think it is... it is a problem with one of the fans (there are 4) in your TV.. It is a simple fix... try using an air canister to clean them. It will require some disassembly though.
Sep 12, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
