Question about Denpa USB-24 Digital Voice Recorder
High sound when recording
When I listen to what I've recorded there is only a high tune. Just an hour ago everything worked perfectly and I have not made any changes in the settings (at least not that I'm aware of). It doesn't seem to matter how I record (telephone conversation or mic). It started in a middle of a recording in which everything sounded normal in the beginning.
  • Anonymous Nov 03, 2007
    Same problem. Every recording sound like it has been made over the phone line
Hi, I'm having problems with the telephone recording using a digital cordless phone. Once the hanset is picked and conversation is going on, the unit does not record???
Posted on Feb 02, 2008
SOURCE:
Sound problems with an Onkyo receiver and a FIOS Set Top Box
If you are not hearing dialogue, then check your center speaker. Most voice tracks are routed to the center channel
Apr 06, 2017 | Onkyo Audio Players & Recorders
My Canon PowerShot SD300 was recording sound perfectly a few days ago. Now whenever I record a video and play it back there is no sound except for static. I have resetted the settings to factory defaults...
When you play the video back and get no sound are you doing this on your camera or on the computer? I have the same camera, and noticed that when I playback something I've recorded I don't have sound either, mind you I don't have static either. But once I've uploaded the video onto my pc the sound is there.
Jul 29, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
I have a TASCAM PortaStudio 424 mkiii 4-track tape recorder-mixer. When I record a new track and listen back to it, everything sounds great. After a couple times of listening to it, and overdubbing other...
It is probably a hard to find record electronics problem and possible that the record bias is staying on partially. This will erase partially the audio and apply the clicks. You are going to need a good Technician for this. Try this guy- I have confidence in him.
New Jersey Factory Service, Inc.
16 Chestnut Avenue Suite 103 B
Emerson,New Jersey 07630
201-967-0060
Fax 201-967-0062
Mon- Thurs 8-4 Closed Fri Sat by appt.
Dec 17, 2010 | Tascam Audio Players & Recorders
I have 2 Sanyo 8080 transcribing machines giving trouble
Hello I recomend to send it to service sound like a Motor problem Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Jun 29, 2009 | Sanyo TRC-8080 Desktop Cassette Voice...
My dell inspiron 1525 microphone does not record.
I have a Dell Inspiron 1525. I used Skype ages ago and returned to it a couple of days ago. No one could hear me. I researched for 20 hours, downloading drivers, checking EVERY setting possible and NOW have got the ANSWER. The wires in the Microphone Array are fatigued. My microphone works perfectly when I tilt my lcd screen half way down. Go to Webcam Manager, Tools, Audio controls, the microphone has 2 bars which go green when you talk into it. Tilt your screen and watch the bars go up and down. Not the answer you probably wanted but as long as you skype with your screen half tilted everything is good to go
Mar 15, 2009 | Dell Inspiron 1525 Notebook
Sony hxd890=rec from hdd to dvd
I had the same problem but changed the recording mode to SP. I used a DVD-RW to high speed dub a two hour film and a documentary about a holiday island.
Both dubs were perfect.
Dec 23, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
There is a crackling sound after I record.
The problem was the VIA chipset firewire card. I changed it with a Texas Instruments one. Works perfectly now.
Sep 04, 2008 | M-Audio Solo Audio External Sound System
Tascam 488 mk II recording problems
Have you taken a look at the edge of the tape? tracks 1 and 2 on a cassette are usually next to the edge and you may have a bad batch of tapes that have the edge damaged. Another possible but not a likley problem might be the tape is out of spec. for the width, and your heads MAY have a little wear from use, and are trying to act like tape guides. If the tape is slightly wider than the grove worn in the head, the tape would be lifted at the edge and not make contact to the head. It is not electronic as you have diagnosed this with other tapes. Give it a try and see!
Aug 05, 2007 | Maxell 109069 Audio Cassette (Type 1)...
Denpa USB-24 Digital Voice Recorder Logo
70 people viewed this question
Top Denpa Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denpa Audio Player and Recorder Expert? Answer questions, earn points and help others
