Question about Proscan PS60690 60" Rear Projection Television
Proscan 60 inch
I have a chasis model ctc171 and my ihvt went out, can I have the whole board swapped out, or do I have to get someone to change the parts themselves, I live in Rialto, California. or can I do it myself.
    Scholar:
  • 150 Answers
You can get ahold of PTS Corp to get the board rebuilt, how do you know the transformer is bad? Sometimes the HV distribution block shorts out. Can you hear the HV "Squeak" 3 times when you press power, if so probably bad transformer. The whole board wont be available new, might be able to pick up a rebuilt one, will have to be careful with the HV leads.
Posted on Jul 06, 2007
SOURCE:
Convergence board swap questions....
You can try to change it out and go to convergence adjustment mode on service mode to setup the template.
But I rather replace couple trans and leaky diode on your old convergence amp board to save my time
Jan 06, 2009 | RCA D61W20 61" Rear Projection Television
Philips 55" HD projection TV
I have been working on solving this problem for a few weeks now myself. I have even purchased 3 broken sets and one good one so that I can do board swaps and test repairs. I have a good idea of what may be causing the problem but the details are too long to put in this thread. Goto the site www.tvrepairkits.com and use the contact us button to send me an email. Include your chasis number or model number. After I receive your message  I will send you an email with some things to check. Hope this helps
Oct 29, 2008 | Philips 60PP9202 60" Rear Projection...
Chassis no PTK195MT
This part is called the flyback transformer and is part # 239111 at a cost of $68.99 from tritronicsinc.com. You can replace the transformer. It sounds like it developed a short internally. There may be other parts that were effected as well. If you are not comfortable working inside hte set, expect a service call to run about $100 for parts plus hte local labor rate.
Dan
Jun 09, 2008 | RCA P60921 60" Rear Projection Television
Power button lights up three times but nothing
I have not answered to this post since you have also joined on my thread with is related to the same problem.
Jan 24, 2008 | Proscan PS60690 60" Rear Projection...
Tv won't turn on
Usually this problem is caused by part failure on circuit board. Most often in power supply or deflection circuit. You will need test equip. and soldering/desoldering tools to fix this set. Most repair services charge 275.00-475.00 to do this repair on a PS60690. Crate is removable by removing rear cover, disconnecting spk. plugs and keyboard plug. Loosen two screws and whole thing slides out. This can save you service call fee.
ProScan 60 inch TV Problem
Have you had any luck with a repair or adjustment?
Oct 09, 2007 | Proscan PS60690 60" Rear Projection...
High voltage splitter
I have read on this forum that for the Proscan 60690 Chasis # PTK 188AC, the HV Splitter part # is 205064 and can be easily purchased on eBay for around $20.- $25.
Sep 28, 2007 | Proscan PS60690 60" Rear Projection...
Open Questions:
Proscan PS60690 1st turns off then on by itself. Then 3 on-off cy I've had this exact problem twice. The 1st time I replaced the RCA part number 205064, which I believe is called the HV splitter. I used a generic non RCA part. The TV worked great for several months but went out again and it has been broken for 2 years. I finally ordered the new true RCA part number 205064 HV splitter. The TV, again seemed to be fixed, and what I a beautiful picture it had through our cable box. But, no happy ending at this point. It worked for a couple of days and then turned off and back on while my wife was watching it a few minutyes ago. It cycled off then back on twice in a 3 minute period so with the picture showing and tv still on she went ahead and turned it off. This is how the problem began several years ago the 1st time it went out. I don't want to turn it back on anymore in case the brand new HV Splitter is still OK. Does anyone know what other parts may be going out, causing the HV splitters to go bad and start shorting out. I know the HV spitters have been an ongoing problem with these sets, but since I just put a brand new RCA one in only 2 days ago I'm wondering if something else goes out first and causes the splitter to go bad after a period of time. I would appreciate any help. I can't afford a new set right now and the picture looks so great on this set using a cable box I feel it's definately worth fixing. ps Could missing o-rings cause this? I've never seen the o-rings. Even the first time I replaced the HV Splitter. Thanks
Feb 28, 2017 | Proscan PS60690 60" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
