Question about Hotpoint Ultima WF860 Front Load Washer
Does not work
We have a ultima cdt 80 dryer and it does not heat proprely it comes up with f-10 on screeen what can i do?
  • paige_lilley Jan 07, 2009
    i want solutions its taking forever
  • Hotpoint Master
  • 3,463 Answers
Error code F10 indicates a faulty thermostat, or the common of the element is open circuit.
You need test the stats for continuity, also the element as well.
It is more likely to be the stats, you must, replace both and not just the one.
Check vents , clean filters
Remove the lower left filter, and wash it through with running water to thoroughly clean it.
Plz rate my solution.
Thanks.
Posted on Jan 07, 2009
WERE IS THE RESET BUTTON ON HOTPOINT DRYER CDT 80
Not sure if all dryers have a thermostat reset. You can check your model (which might be CTD80 and not CDT80). Usually it can be reset if there is a small hole in the middle of the device where you can insert a tooth pick and press it.
Location of thermostats is at the back. Make sure the power chord is unplugged from the wall.
See this youtube video.
how to replace Hotpoint tumble dryer thermostat
Sep 01, 2014 | Hotpoint Dryers
Hotpoint ultima logic sensing condencer TDC62 is not drying clothes, it doesn't appear to be heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
Kenmore 80 series dryer, no heat. blower works
Check to see if the glow bar is coming on first. If it isn't, it is probably the thermal fuse/ cutoff. It is a small white plastic piece on near the motor housing.
http://www.partselect.com/PartDetail.aspx?Inventory=345113&SourceCode=6
or
http://www.partselect.com/PartDetail.aspx?Inventory=344958&SourceCode=6
If it is coming on but not lighting the flame, then you probably need gas coils. They are the two cylinder shape black and white objects attached to the gas valve.
http://www.a-1catalog.com/gasvacokit2.html
Jan 15, 2010 | Kenmore 73952 Gas Dryer
My series 80 dryer squeaks
do not lubricate anything in a dryer you will damage .locate the the squeek if it is coming from the rear of the unit most likly need to replace the drum support or wheels if its intermittant and has a squeek squeeek noise that either gets worse or goes away when the dryer heats up the tensioner pully or the moter berrings are bad
Aug 10, 2009 | Dryers
No heat
First thing to check are cutouts located above element. Should have continuity on both. take care element is fragile. Some models have a third located in the door space although this one is rarely prone to fault.
Nov 16, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error code F 13
f-13 is heating element or thermostat.
remove plastic panel at bottom back, look for black marks in line with the heating element at bottom middle of drum.
part number: 1604486 may fix your problem
Mar 24, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Ultima Condensor Dryer
on the back of your dryer you have a heater behind the protruding panel... Either you heater element has gone, but most like the thermal cut outs have blown...these are located in the same area..they are small and round looking and are connected to them are wires either side. Anyways check the conitunity of the termal cut outs using a tester if no continuity then they are no good... hope it helps...
Nov 18, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
116 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
