Question about Sony STR-DE545 Receiver
Sony STR DE545 Rear Speaker Problems
Hi! I've been having the same problem as others have been posting with the rear speakers going out and, shortly after that started, the unit periodically goes into "protect" mode. Turning the unit off and then back on seems to solve that for now. It all started after I moved the amp into a cold garage for about 3 days during a remodel, so it's likely that the temperature change affected the connections. I opened the case, straightened some transistors, and separated some things that I thought probably shouldn't be touching, and they came back on. However, the "solution" was short-lived. Also, the unit has also always produced a little hiss. I'm interested in trying the solution that worked for you, but I'm a novice at this. With that said, can you provide a little more instruction on how to go about it, or is it probably better just to bring it to a repair shop and let them try? Thanks in advance!
  • 4 Answers
The symptoms seems very likely that the solders on the PCB have cracked. These are the solder on the contact points with the "Blue Relays". Removing the various small boards and pulling out the main board is relatively easy. But to solder, you need the soldering gear and skills. If not done carefully, the whole board can be ruined. Taking it to a small repair shop and getting it soldered will be a better option.
Posted on Jan 10, 2009
I have a buzzing coming through my speakers the radio and cd display playing but no volume just buzzing I have learned that it's a direct short but where to do I look to find it? Need help
Hi Shelly
Find the security flat tool to release the radio from the dash.
Check the wires at the rear of receiver / amp
Disconnect from existing speakers and attach temporary other speaker.
Or
Remove unit & bench test
Mar 11, 2016 | Car Audio & Video
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
How do I replace the tweeter on Mordaunt Short Avant 906i speakers?
Hi - Just reading your problem with the 906's and removing the front cover to replace the tweeter. Did you ever solve the issue? because I tried today and I can't budge the silver cover once the screws have been removed. My email address is chris.clemons@btinternet.com if you can help - thanks
Feb 16, 2012 | Mordaunt Short 906 Rear Speaker
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
Str-de545 sony not putting out sound to rear speakers
From page 46 (Troubleshooting)-
No sound or only a very low-level sound is heard from the rear speakers.
>>> Make sure the sound field function is on (press SOUND FIELD - MODE).
>>> Select a sound field containing the word "cinema" or "virtual" (see pages 28-30).
>>> Adjust the speaker volume (see page 19).
>>> Make sure the rear speaker size parameter is set to either SMALL or LARGE (see page 17).
Jan 11, 2011 | Sony STR-DE545 Receiver
Hi, just wanted to know if there is a diagram for the head unit. the colours for the left & right speakers in a ve ute?
*Remove drivers side centre console panel
*You'll see a black plug on the "side" of the stereo, this is your speaker outputs and constant 12v+.
Dark Green - / Light Green + = Front Right Speaker
Grey - / Brown + = Front Left Speaker
Light Blue - / Dark Blue + = Rear Right Speaker
Yellow/Red - / Brown + = Rear Right Speaker
Sep 21, 2010 | Car Audio & Video
PROTECT MESSAGE
It senses an error or problem and shuts down. Try disconnecting all the cables and wires attached to it. Try it again. If it still shows protect message, it is an internal fault and requires a repair shop. If it clears up, then the problem may be a shorted speaker wire. Correct the short when reconnecting the speakers.
Mar 08, 2010 | Sony STR-DE545 Receiver
Yes I have a problem with my sony str de 525 receiver its stuck on Protecter every time i turn in on it flashes protecter and i cant get it to stop what do i do
Disconnect the speaker wires from the rear panel, turn the volume down, and see if the receiver still goes into protect when you turn it on. If it doesn't, you need to check your speakers and wiring. You may have a speaker that's gone bad, or a wire that's shorted. Likely causes are too much insulation removed when you stripped the ends and now they are touching, the wire's been pierced by a mounting nail or staple, or it's been damaged somehow.
If the receiver still goes into protection with no speaker load, it's the receiver at fault. I have seen this problem caused by bad solder connections on several areas, bad components in the power supply, and trouble in the amplifier section.
I can't point you toward any specific "most likely" cause, but the bad soldering is something you can check by eye. Any other cause is probably going to require service by a technician who has the test equipment and service information to do more in-depth troubleshooting.
Good luck, and thanks for using Fixya!
Mar 05, 2010 | Sony STR-DE545 Receiver
Vibration sound - Mordaunt-short 906
Thanks for your interest...not yet solved...but friend who is hi-fi enthusiast says he knows what it is and will take it to where it will be fixed...know this sounds very vague...'me mere woman'....think he said something about some inner coil which needs replacing (or something like that) Sorry for explanation, I have no idea. Thanks anyway. Laj.
Dec 27, 2009 | Mordaunt Short 906 Rear Speaker
Sony STR-DE545 Receiver Logo
448 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
