Question about Video Cameras
The cassette door on my HandyCam Pro CCD-V9 only opens part way.
The camera has no cassette inserted. When I activate the push the tab to open the cassette chamber the camera makes the usual noise the top opens only about 3/4" and the front of the cassette chamber does not open out as it should; probably because the top does not open high enough. After 2-3 seconds the top descends as it should. To my knowledge the top has not been forced down at any time. Otherwise the camera appears to be in working order. Is there a way to physically open the cassette chamber?
  • 196 Answers
The problem is usually caused by no drum rotation. Have it serviced.
Posted on Feb 13, 2006
  • 3130 Answers
SOURCE: "reinsert the cassettee" error in Sony HandyCam CCD-TRV 438E.
The camcorder most likely is not detecting the tape, you have a bad sensor and these sensors all come on a flex type board and the flex board is mounted on the chassis surface. This will mean that the entire mechanism will meed to be diassembled, and is a very big and costly job. My opinion is that this repair will run you abut 250 to 300 bucks and this camcorder is not worth this as new camcorders are under 200 bucks. Good Luck
Posted on Apr 03, 2007
  • 41 Answers
SOURCE: Old Sony Handycam Video 8 CCD TR36
Head alignment (re-aligning the tracks) is not something we as owners can undertake - it has to be done professionally.
You can however quite safely clean the heads by using one of the dry cleaning tapes sold for the purpose. I have used an 8mm/Hi-8 cleaning tape made by TDK for a number of years with good results. Remember that if your heads are dirty both recording and playback will be affected and once you have cleaned the heads you need to test the camera by recording new footage and then playing it back to see if matters have improved. Good Luck.
Posted on Apr 29, 2008
SOURCE: my sony handycam ccd-tr716
Use an ink pen and press the reset button on the lid of the cassete right beside the eject button.
Posted on Sep 02, 2008
  • 405 Answers
SOURCE: Sony Handycam CCD-TR64 cassette door won't close
Common problem with this mechanism. In order to fix the problem you will have to replace part called CHASSIS LS. Expensive repair, probably not worth the effort.
Posted on Dec 04, 2009
Testimonial: "Thanks. We ended up getting a new camcorder. That Handycam was as old as I am (18 years), so it was time for an upgrade anyway."
Tape doesn't stay down, keeps popping back out of cassette, on my Sony CCD-TVR608. Any ideas?
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Aug 17, 2010 | Sony Handycam CCD-TRV608 Camcorder
I have a Sony Handycam Video 8 ccd-TR330E PAL.
how to transfer video to computer, any cable ?
Feb 23, 2010 | Sony Video Cameras
Dec 04, 2009 | Sony Handycam CCD-TR64 Camcorder
I get an eject symbol and beep and error code c32:11, original issue was that it ate a tape
The error C 32:11 denotes for mechanical unsuitability, This problem appears when the improper insertion of the cassette been done, or lose cassette tape stuck,
In all these situations mechanical adjustment is required, You are suggested to please contact any expert for the mechanical adjustment.
Hope you will understand my sayings.
Thanks for using fixya.
Jul 11, 2009 | Sony Handycam CCD-TRV68 Camcorder
Cassette jammed after camera dropped
I think your ejecter motor is not working.temporarily open with any tool.
Dec 10, 2008 | Sony Handycam CCD-TRV107E Camcorder
Cassette stuck
If battery is fully charged and unit still will not open, try removing the tape door and see if there is tape wrapped around capstan or ther parts. If you cannot find anything apparent, take unit to qualified pro tech
Jun 09, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam CCD-TRV 72 cassette door locked open
Sorry I can't directly help with your problem but I advise you the repair cost at a repair shop would probably cost nearly as much as a replacement...
Unless you have a handy friend who works cheaply you won't lose anything by repairing it yourself. You will probably find some useful how-to videos to help you on Youtube.
Mar 14, 2017 | Sony Video Cameras
TR5 65E
try to inspect the mechanical lock! or maybe you have some debris or some solid matter not part of your handycam, inside the mechanical cassette that why your door not open.
Nov 02, 2007 | Sony Handycam CCD-TRV107E Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Video Cameras Logo
174 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
