Question about Western Digital Caviar WD1600 (1600YD) 160 GB Hard Drive
Can I use a WD3200AAJS as a slave drive. If so what is the jumper configuration.
    Scholar:
  • 34 Answers
Hello!
The drive you have is a SATA drive, and has no master/slave configuration as such.  There is a connector block on the back to configure other options such as spread spectrum clocking.  Normal configuration is a jumper between pins 1 and 2 (all the way on the right side, facing the back).  A picture of the other configuration options is shown below.
Hope this helps you out,
Ken
Posted on Jan 08, 2009
  • app_3rp1228
    app_3rp1228 Jan 16, 2012
    Could we have a larger version of the jumper settings, this is unreadable.
WD 3200AAJS jumper settings for slave
Sata drives have no jumper settings. The computer will find it when you install it.
Mar 03, 2013 | Western Digital WD Caviar Blue WD3200AAJS...
How to slave a WD3200AAJS Hard Drive
Sata drives require no jumper settings. Just install it and the computer will do the rest.
What jumpers are for slave Western Digital WD Caviar Blue WD3200AAJS - hard drive - 320 GB - SATA-300 SATA
SATA drives don't need jumpers. Just install the drive and the computer will assign a drive letter.
Jun 06, 2012 | Western Digital WD Caviar Blue WD3200AAJS...
How do I make a WD3200AAJS hard drive into a slave drive?
You have to change the jumpers on the drive see the picture for jumper settings
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 02, 2011 | Computers & Internet
Can we use Excelstor Gstor as a Slave Drive? If yes, how? What is the jumper setting required?
To configure the hard drive as a slave drive, you need to set a jumper on the hard drive to SL (slave)
The other jumper settings are MA (master) and CS (cable select).
Mar 20, 2011 | Excelstor Technology J880 Hard Drive
How do i configure this hard drive for a 'slave' ?
Hello
Ok, you ill be able to see the jumper configuration on the hard drive itself. Here is an example on what the jumper diagram will look like on a hard drive.
Now, all you need to do is to have a look on your hard dive and see where you need to place the jumper for the slave configuration. Here is what a jumper looks like.
After you have done this, you only need to plug the hard drive into your pc.
Hope this can be of help.
Kind regards
Aug 13, 2010 | Quantum Fireball 15 GB ATA-66 Hard Drive
I would like to make this a slave so that my 500 GB PATA HardDrive will be the master as that has my operating system and the Plextor PX-716A drive will be the slave?
You need to configure the jumper at the back of the drive as shown in the following picture
Configure the CD/DVD drive as slave, configure the hard drive as Master.
Mar 13, 2010 | Plextor PX-716A (PX716ASW) DVD±RW...
Need master slave configuration
You should have a jumper configuration written somewhere on the front (up) side of the hard Disk ... Look there, or look just around the Pins... Look for M, S, CS (Master, Slave, Cable Select)
Darko, Serbia
Mar 20, 2009 | Western Digital 60GB U100 5400RPM 2MB...
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Hi i have a 10.1gb Maxtor model 31024H1 IDE hard drive and i need the jumper setting for slave
slave is NO jumpers at all
(Master) - The vertical jumper over the J50 pins is configuring the drive as a Master. The horizontal jumper over the J48 and J46 pins is in the Storage position.
(Master with CLJ) - The vertical jumper over the J50 pins is configuring the drive as a Master. The vertical jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Slave) - No jumper is required to configure the drive as a Slave. The jumpers over the J48, J46, J44 and J42 positions are both in the storage position.
(Slave with CLJ) - The jumper over the J44 and J42 positions is in the storage position. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Cable Select) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J44 and J42 pins is in the storage position.
(Cable Select with CLJ) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
Oct 13, 2008 | Computers & Internet
Western Digital Caviar WD1600 (1600YD) 160 GB Hard Drive Logo
4,301 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
