Sir i have p4 system with intel 845.now i upgrade my system to mobil intel pentium 4 .in this case ican't use my old hard drive with the opperating system of xp. so what should i do use same hard disk with out doing install again.
  • 66 Answers
Yes you can use it but it needs some other drivers to install. be sure that you have a complete driver of your PC most especially mother board,VGA, CAM, PRINTER, LAN and other accesories that you install to your PC.
Posted on Jan 08, 2009
Drivers for intel 845 gvsr with p4 2.4 gHz for windows 7
please visit the website below and search for your board 845 then select your operating system in the right hand box and the drivers that are available will be show below hope this has helped http://downloadcenter.intel.com/Default.aspx
May 22, 2010 | Intel D845GVSR Motherboard
Swaping hdd 845 motherboard to 915 motherboard
its always safe to have data backed up
u can swap the HDD
but bootup with the Win2K CD in the Drive and after the files are loaded at the first screen select install then after it detects the OS select R (Repair) and this will reinstall the operating system files and then you can use the system as before though u may have to install the device drivers and motherboard drivers
for any other clarifications u can place a comment in the same question or u can mail me at mail2pvs@gmail.com
Jul 30, 2009 | Intel Pentium 4, 3.0 GHz 530...
Cannot change cmos settings.
Try this.
Open case somewhere on motherboard will be (reset BIOS) or word to that effect. it will be a small 2 pin connector with a jumper on 1 pin connect the jumper across both pins for 30 seconds remove jumper fit back over 1 pin (not get lost) reboot your BIOS should have reset to default hope this helps post comment if does please
Jul 27, 2008 | Intel Gigabyte GA-8IDX 845 AGPset P4...
P4 Pentium
The GA-8IE comes with the 845E chipset. The below link will provide a list of all the processors the board will support.
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1320
It appears that the fastest it will support is the P4 Prescott, Northwood, or Extreme @ 3.4GHz (800MHz FSB).
Hope this is the information you were looking for.
MO
Jul 04, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Changing motherboard
Since both boards use the same chipset (Intel 845), you shouldn't have any problem with components. (The one possible glitch will be the memory - some motherboards are a little picky.)
Keep in mind that you will likely have to reformat the hard drive and reinstall your operating system and programs, but sometimes you get lucky. (Even then, if you're running Windows XP, Microsoft is likely to ask you to reactivate.)
More info and drivers are available for download here:
http://www.asrock.com/mb/overview.asp?Model=P4i45GV%20R5.0&s
Good luck.
May 28, 2008 | Intel Motherboard
250gb sata hard disk to 845 glad mother board
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Thanks so mcuh!!!
May 12, 2008 | Computers & Internet
Upgrading
To upgrade from pentium 3 to P4 you have to change alot of the hardware.
You need a NEW P4 Socket mPGA 475 Motherboard.
New DDR RAM
New 478 PIN Processor.
You can use the old CD rom and Hard drive and any other PCI card but You Need the Mentioned Hardware to Upgarde.
Jan 08, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
