Question about GE 25922 Cordless Phone
I have a GE 25922 5.6GHz cordless phone. It has 3 receiver. 1 of the receiver all ways says unavailble and it does not ring or can't call out. Can you help me with phone? Thank you, Sai.
  • Regina B Jan 13, 2009
    Also Looking for the same solution. Has anyone contacted/ called GE
UNAVAILABLE Indicates the handset is out of range. Or an additional handset is in use. Or there has been a base power failure, in which case you must place all handsets on the main base cradle for 20 seconds to re-register.
Posted on Feb 07, 2009
How i can set up only 3 rings before going to answering machine?
Use the RINGS TO ANSWER switch on the back of the base to set the number of times you want the phone to ring before the answering system answers the call. You may choose 3 rings, 5 rings, or TOLL SAVER (TS).
You can download the manual at
http://www.home-electronics.net/ge/pc/IB/25952EE1_IB.pdf
May 10, 2011 | GE 25952 Cordless Phone
My phone goes to voicemail after 3 rings. how do i change that to 5 rings?
do you have the phone with an answering machine like:
http://www.generalmanual.com/Telephones/GE-25932EE1-Cordless-5-8GHz-Edge-Phone.htm
Or are you using a voice mail system on your phone line? If so, contact the voicemail company or your phone company for information on how to change the number of rings before the forward.
EJ Kudelka
Apr 29, 2011 | GE 25932 Cordless Phone
Samsung prostar 816 plus system ringing problem
sounds like your having a couple of problems at the same time. the lines only ringing at station 1 is the default setting of the system my guess is that the time and date are also way off if thats the case.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
next, the problem with the cordless not working has to do with the port programming, in default it assigns all ports as multiline sets.
To assign a SLT(single line telephone) port to the system while still in program mode dial #38 the screen should say slt dial type and then 16 0's.
0 = keyset 1=slt set
enter in all 16 digits followed by the # i.e.if your cordless is on port 7 it would look like 0000001000000000 #
lastly the phone that can no lnger recieve calls sounds like the do not disturb or DND has been pressed to stop the alarm from ringing. press the mute/dnd button (light should be off). to cancel an alarm press the ALM/SD button twice and then the hold button.
hope that helps out.
Mar 05, 2009 | Samsung Prostar 816 Phone
Can I use cordless phone answering machine even if I have voicema
You do not have to cancel the phone company voice mail service. You need to change the number of rings the phone uses to answer the voice mail.
For example, if the telephone company voice mail answers if 4 rings, set the telephone answering machine to answer in 3 rings or less.
Good luck.
joequevedo@charter.net
Mar 03, 2009 | GE 27992GE5 Cordless Phone
My friend ring me they here the rings but i fail to listen at my end
For GE : There is a button on the base lower right corner  (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE  GHz:
 1. Pick up the phone handset and dial *98.
2. Press 2 to disable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Hope this helps!
Jan 30, 2009 | Uniden Cordless Phone
Dialtone
http://www.retrevo.com/samples/GE-manuals.html
follow the link above and also try to get an earlier or newer moddel manual ;) take care
Oct 22, 2008 | Uniden Cordless Phone
Cordless Phone
When trying to make a call,messages appears unavailable on both hand sets that i have,i can not receive or send calls, but my land line does.
Oct 05, 2008 | GE 25932 Cordless Phone
No dial tone
no dial tone on my cordless
May 01, 2008 | GE 25932 Cordless Phone
Turn off ringer?
On the base, to turn the ringer off, press and hold Volume Down [V] until the unit beeps 2 times. On the handset you can use the menu to turn off ring. This way, you can choose to receive and take the urgent calls.
Apr 04, 2008 | Panasonic KX-TG2313 Cordless Phone
GE 25922 Cordless Phone Logo
237 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
