Question about HP Photosmart 3180 All-In-One Printer
I can't seem to figure out how to get the ink cartridge out of the printer.
    Sergeant:
  • 367 Answers
Here is a video on replacing the in cartridge, I couldn't find one for your exact model but for inkjects they are all pretty close.
Posted on Jan 07, 2009
Hp 7500a "The following ink cartridges appear to be missing or damaged"
clean the gold contacts where the ink cartridges seat with alchol and microfiber towel replace ink cartridges.
Jan 21, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
I can't seem to install my ink cartridge correctly. Do you have a picture demonstration on how to do this? I continue getting an error message.
Installing the print cartridges Follow the instructions below to install the print cartridges: caution.png CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
  1. Remove the print cartridge from its packaging and carefully remove the plastic tape from the copper strip. Figure 2: Removing the plastic tapec00109809.jpg
  2. With the power on, open the printer's top cover. The cradle moves to the center of the printer.
  3. Hold the print cartridge so that the copper strip is on the bottom. Figure 3: Holding the print cartridgec00109811.jpg
  4. Insert the cartridge into the cradle at a slight upward angle until you feel resistance. Figure 4: Inserting the print cartridgec00109813.jpg
  5. Firmly push the cartridge into the cradle. You will hear a snapping sound when the print cartridge is correctly positioned. The print cartridge fits securely in its cradle. Figure 5: Print cartridge in correct positionc00109815.jpg
  6. Close the top cover.
  7. Calibrate the printer for optimum print quality.
    Best of luck!
Sep 06, 2011 | HP Office Equipment & Supplies
My printer canon mp190 says the ink cartridges are not recognized. The same ink cartridges have been working. I can't figure out why of a sudden they aren't recognized.
It seems to me that these ink cartridges are not Cannon. This can happen anytime. I would suggest you get original Cannon cartridges. It always pays to get the real thing.
Hope this helps.
Apr 07, 2011 | Canon PIXMA MP190 All-In-One InkJet...
"Print carrier stall"?
Error 0502-Carrier Stall indicates a physically blocked carrier. This condition can occur for many possible reasons. Most often, the carrier is blocked because the ink cartridge lids are open while the printer is on (Figure 1).
Figure 1: Open Ink Cartridge Lids
Reseat the Ink Cartridges and Make Sure the Lids Are in Place
  1. Make sure the printer is turned on.
  2. Lift the printer's front cover.
    new_note.jpg Note: The ink cartridge should be in the up/loading position unless the printer is busy.
  1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
  2. Remove the cartridges.
  3. Make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
  4. Replace the cartridges.
  5. Snap the lids closed.
  6. Close the printer's front cover.
  7. When prompted on the printer's LCD to choose New or Old, choose Old.
  8. Press Select.
new_note.jpg Note: For more information about reseating ink cartridges, refer to the Maintenance or Ink Cartridge Maintenance section in the Online User's Guide.
Back to Top
» Reposition the Encoder Strip
  1. Remove the power cord from the printer.
  2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
  4. Gently move the top part of the printer belt to the right.
  5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    Figure 1: Inkjet Printer Encoder Strip
  6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
  7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
  8. Once the encoder strip has been re-seated, close the scanner lid.
  9. Re-connect the power cord to the printer.
Jul 18, 2009 | Dell 922 All-In-One InkJet Printer
Won't print after replacing cartridges
The following text copied from HP website to tackle this problem. minimtop.gif Follow the instructions below to install the print cartridges. NOTE: If you are installing ink cartridges in the unit for the first time, be sure to use only the print cartridges that came with the unit. The ink in these cartridges is specially formulated to mix with the ink in the print head assembly at first-time setup. s.gif Installing the print cartridges minimtop.gif
  1. Verify that the unit is on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00718797.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00721793.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
  4. Remove the new ink cartridge from its packaging.
  5. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot. NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted. Figure 3: Inserting an ink cartridge c00721795.gif
  6. Press down on the gray latch until it clicks into place. Figure 4: Closing the gray latch c00721796.gif
  7. Repeat steps 3 through 6 for each ink cartridge that needs to be replaced. NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  8. Close the ink cartridge door. Figure 5: Closing the ink cartridge door c00718798.gif
s.gif s.gifHave a Good Day
Jul 17, 2009 | HP Photosmart C4580 All-in-One InkJet...
Dell Printer A940 Hardware error
Back to Top
» Reseat the Ink Cartridges and Make Sure the Lids Are in Place
  8. Press Select.
Back to Top
Jul 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
HP C7280 Printer not priting wirelessly.
Solution Replace the indicated ink cartridge(s), or press OK on the control panel to continue. HP recommends the use of genuine HP ink cartridges. Genuine HP ink cartridges are designed and tested with HP printers to help produce great results, time after time.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage due to the use of non-HP ink will not be covered under warranty. Follow these steps to replace the depleted HP ink cartridge(s). Step one: Replace the indicated cartridge(s)
  1. Make sure the HP All-in-One is turned on.
    NOTE: The Attention light blinks when the product is turned on.
  2. Open the access door by lifting from the front center of the HP All-in-One, until the door locks into place. Figure 1: Opening the access door c01079714.jpg
  3. Squeeze the bottom of the latch below the ink cartridge to replace, and then lift the latch.
    • To replace the black ink cartridge, lift the latch on the far left.
    • To replace one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
    Figure 2: Lifting the latch c01079715.jpg 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
  4. Pull the ink cartridge towards you out of its slot to remove it. Figure 3: Removing the ink cartridge c01079716.jpg
  5. Remove the new ink cartridge from its packaging.
  6. Holding the new ink cartridge by the handle, push the ink cartridge into the empty slot. Match the color and pattern of the ink cartridge to the color and pattern on the print carriage. Figure 4: Inserting the new cartridge c01079717.jpg
  8. Close the access door. Figure 5: Closing the access door c01079719.jpg
Step two: Align the new ink cartridge(s)
  1. Make sure paper is loaded in the input tray, and then press the OK button. The HP All-in-One prints the alignment page, aligns the printhead, and initializes the ink cartridges. This takes approximately 5 minutes. CAUTION: Do not disconnect or turn off the HP All-in-One during this time. You may hear the HP All-in-One making noises.
  2. Check the display for status, and then press the OK button. Recycle or discard the alignment page.
Cause The original HP ink in the indicated ink cartridge(s) has been depleted.
May 24, 2009 | HP Photosmart C7280 Laser Printer
My printer wont print, plus the black ink seems to not work
maybe your ink cartridge is damaged. Try to change your ink cartridge (black). Or your printer has reach the maximum capacity of pritning.. ^^
Jan 28, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart 3180 All-In-One Printer Logo
Seeker5211
Seeker5211
